Like Tree25Likes
Old 04-25-2017, 12:51 PM   #196
IndyRC_Racer's Avatar
Has anyone used the Tamiya anti-wear grease on their friction dampers (the stuff for the gear diffs)? I've had success using anti-wear on my M-03 friction dampers, but they are a different design.
However per the kit instructions it doesn't say to put any type of grease/lubricant on the dampers.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 04-25-2017, 01:24 PM   #197
Trader Rating: 62 (100%+)
It has been done. Different situations require grease and some without is manageable. Team green pretty much tried other stuff too. Having an extra set of shocks is probably wise to have. I would do one set with grease and other set without or different type of grease
sipaboy is offline   Reply With Quote
Old 04-25-2017, 05:35 PM   #198
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
The rules state built exactly per instructions. My interpretation would be not playing with diff oils, grease etc...but I've seen it posted that gluing sidewalls isn't allowed and virtually every truck I've seen has the sidewalls completely covered in CA so???
Maybe a clarification before Nats is in order so people are prepared.
team green likes this.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-25-2017, 06:14 PM   #199
Laguna Bozo's Avatar
+1 on that!
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 04-25-2017, 07:31 PM   #200
team green's Avatar
It clearly states in the rules you can use any oils or grease on the gears or any moving parts.
I've been to 2 regionals. In Fresno we were told no CA on sidewalls and all parts must be used. In Aliso in tech I saw tires that's have been CA'd and motor guards removed. I asked about that and tech said it was ok.
So two regionals two different answers. So yes we do need carification. I personally do not CA my sidewalls.
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Tamiya TA07 Pro
Associated B6
TLR 22-4 2.0
team green is online now   Reply With Quote
Old 04-27-2017, 12:34 PM   #201
That sucks. Box stock already getting out of control lol.
Class is super fun though, it's like a break in between real racing
[Yokomo 16' BD7 17.5 Stock] [Yokomo 16' BD7 21.5 USGT] [Tamiya TT-01E Hahn Truck] [Tamiya TA06 Exo 17.5 Stock *Retired*]
DaSilva3525 is offline   Reply With Quote
Old 04-27-2017, 02:56 PM   #202
JayL's Avatar
That's what happens: everyone thinks they are not winning because the winner has super motor or super battery or magic, so they switch to a 'all run the same everything' class and still don't win so they want to push the rule limits, or change them.
been that way forever......
moistAF likes this.
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 04-30-2017, 01:39 PM   #203
ThrottleKing's Avatar
Trader Rating: 16 (100%+)
We don't do the sidewalls but just the break over from the contact patch to the sidewall. About 2-3mm of CA. For us it's the ticket to eliminate tractor roll and minimizes the bounce on carpet. We have to make it marketable here so the shop can sell kits and keep the doors open.By marketable I mean it has to be user friendly enough that anyone can buy and race it on carpet without overcoming difficult handling issues that some newcomers will struggle to grasp.
vivo quevas likes this.
ThrottleKing is offline   Reply With Quote
Old 05-03-2017, 09:02 PM   #204
marshallsbbq's Avatar
Trader Rating: 39 (100%+)
Default Euro truck Bounce
Has anyone figured out how to stop all the bouncing. I built my kit per instructions exactly and I been racing with other guys and no bounce. This is supposed to be a spec kit but with all the bouncing it puts me at a disadvantage. I am a whole second slower with all the bouncing.
Kevin
SoCal Eco Cleaning
marshallsbbq is online now   Reply With Quote
Old 05-04-2017, 04:38 AM   #205
AW grease on the internal rim part of the front dampers works a treat to calm down the front end.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-04-2017, 04:45 AM   #206
fyrstormer's Avatar
They don't let you glue the tires???
EDIT: Oh, you mean glue on the outside of the sidewalls, to reduce traction if the sidewalls dig into the ground. Interesting idea, I'm embarrassed to admit I never thought to try that before.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 05-04-2017, 04:58 AM   #207
GrandeGixxer's Avatar
I am running graphite grease in the dampers and there is a little bit of bounce, but not a whole lot. A lot less than most trucks I've seen on videos. I think that the key is getting them to be smooth, not really sticky by putting high viscosity substances in them.
eR1c likes this.
GrandeGixxer is online now   Reply With Quote
Old 05-04-2017, 05:09 AM   #208
howardcano's Avatar
Trader Rating: 35 (100%+)
Don't be surprised if carpet tracks don't allow anything in the dampers. Since the dampers aren't sealed, all that glop and sticky stuff will find its way onto the track. That makes the carpet ickey.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 05-04-2017, 01:35 PM   #209
team green's Avatar
Black wheels
Awesomatix EVO2
Tamiya TA07 Pro
Associated B6
TLR 22-4 2.0
Old 05-23-2017, 01:52 PM   #210
Some Euro Truck action from the RC Madness TCS Race.
https://www.youtube.com/watch?v=F1fL...ature=youtu.be
CallousStarr is offline   Reply With Quote
tcs in washington subaru73 Northwest Racers 937 08-05-2017 11:18 PM
Tamiya GT Pro Spec Class angrymelon Electric On-Road 15 02-17-2017 10:28 AM
2016 RC Car World On Road schedule RCCarWorld Mid Atlantic RC Racing 971 10-14-2016 07:27 AM
Tamiya Championship Series 2016 TCS Core Creations Nebraska/Iowa Racing 86 03-12-2016 06:37 PM
