Like Tree25Likes
Old 04-17-2017, 07:11 AM   #181
Laguna Bozo's Avatar
Do you know the part # for the lower body, and/or its availability? Thanks.
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 04-17-2017, 07:22 AM   #182
bdemegs's Avatar
Trader Rating: 18 (100%+)
TAM1825882
Ther are some on eBay, other places stores have a available soon statement
bdemegs is offline   Reply With Quote
Old 04-19-2017, 06:36 PM   #183
bubbaslash's Avatar
I hope this class takes off enough for the aftermarket to create some different bodies for these things. Add a little variety on the track.
Sleeper Slash 2wd HCG VXL
Chuckworks Slice Super B
Chuckworks Slice A6 gone oval
TLR/Exotek chassis 22SCT 2.0 MM
X Factory SCX-61 prototype
bubbaslash is offline   Reply With Quote
Old 04-19-2017, 06:58 PM   #184
MD
MD's Avatar
Trader Rating: 113 (100%+)
Here's one.
EURO RACE TRUCK BODY 200MM RIG SEMI TRANSPORT TOURING SERPENT XRAY TAMIYA | eBay
MD is online now   Reply With Quote
Old 04-19-2017, 07:49 PM   #185
gigaplex's Avatar
Being a TCS class kinda rules out the usage of aftermarket bodies.
gigaplex is online now   Reply With Quote
Old 04-19-2017, 08:16 PM   #186
MD
MD's Avatar
That's true if your running strictly for the TCS, but there other tracks running them.
Old 04-20-2017, 04:43 AM   #187
This is a copy of the body Yokomo offered about 10+ years ago.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 04-24-2017, 01:23 PM   #188
eR1c's Avatar
Okay, I have two full race days under my belt on this car and plenty of practice.
My observations,
Friction damper position (inner vs outer hole and every combo -front inner rear outer, and vice-versa) doesn't not seem to make a difference. I raced w/ some fast guys, the top two both ran different damper positions. I have tried all and can't tell a difference.
Heavy oil vs light oil on friction dampers. I have tried no oil, thin grease and heavy 1mil tacky diff oil. Top drivers at our track went for thin smooth NOT tacky or thick. I'd say that using tacky 1mil diff was bad and didn't allow the car's dampers to actually do their thing. Made the ride too hard and thus extra bouncy.
Driving style seems to be key. Hard exhilaration then jam on the breaks before the turn then hard exhilaration again. I avoid most of the bouncies w/ this technique. Coming in to turns w/ a ton of speed does not seem to work well, otherwise you hop all over the place. I have my brakes set to about 60% of full breaking, thus my brakes are a bit "soft" ...so it doesn't stop in place yet slows nicely when I "jam" the brakes.
I am running my car box stock w/ exception of bearings (per rules for the various clubs I've run with). I've heard rumor of people cheating around the pits, and have had other drivers recommend I try things that are not legal w/ my truck. I don't care to take part in any of that so won't even mention what techniques I've heard. -but I am sure people are cheating. I'd rather lose honestly than win dishonestly.
I am running the front diff w/ extra TAmiya anti wear grease and the rear w/ the recommended amount. I plan on trying various weights in the diff and see how that helps/hinders.
keep in mind this is just my experience and my 2 cents. Hope it helps.
I'd love to hear what works w/ the diff if anyone has tried (no oil, med, thick -front/rear)?
GrandeGixxer likes this.
eR1c is offline   Reply With Quote
Old 04-24-2017, 04:06 PM   #189
team green's Avatar
My observations,
Hey, Eric it's Jason. My wife and I pit next to you at P1 Sunday.
He is my setup I used.
Rear diff AW grease 3/4 full
Rear shock Kyosho 30k diff grease very little. Shock mounted on outer hole.
Front diff 20 million diff oil
Front shocks Kyosho 30k diff grease. Very little.shocks mounted in outer hole.
Also added 64 grams of weight to the battery side.
My wife's truck was setup the same way but with only 14 grams of weight to the battery side.
team green is offline   Reply With Quote
Old 04-24-2017, 05:15 PM   #190
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
it this TCS legal?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 04-24-2017, 05:19 PM   #191
team green's Avatar
Originally Posted by OVA View Post
it this TCS legal?
It sure is I've raced two TCS events (Fresno,and Aliso). Finished 3rd in Fresno and 2nd at Aliso.
In Fresno I didn't use weights in Aliso I use 28 grams.
Old 04-24-2017, 05:50 PM   #192
Weight is allowed Really? Almost every club that is racing Hahn trucks atm are under the impression adding weight / balancing or removing weight was a no go. Pretty sure 99% seem to follow box stock with bearings only..
I feel like the weight adding is the gateway to more.... why though.
[Yokomo 16' BD7 17.5 Stock] [Yokomo 16' BD7 21.5 USGT] [Tamiya TT-01E Hahn Truck] [Tamiya TA06 Exo 17.5 Stock *Retired*]
DaSilva3525 is offline   Reply With Quote
Old 04-24-2017, 05:59 PM   #193
bdemegs's Avatar
My observations,
Firstntime out i ran with 200k in the front diff. Kit tamiya grease in the rear. Some 200k on the friction dampers. Can't say i recall how my shocks are mounted. First week both my sons and my truck were like this and were on point all night. Last week we both struggled, but i didn't do any maintenance so its ptobable that the shocks need cleaned and redampened.
Old 04-24-2017, 09:09 PM   #194
team green's Avatar
Removing weight like dremeling or drilling parts to save weight is not allowed. But no where in the TCS rules say adding weight is illegal. I passed tech and I wasn't the only one using weights at these events.
eR1c likes this.
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Tamiya TA07 Pro
Associated B6
TLR 22-4 2.0
Old 04-25-2017, 12:10 PM   #195
eR1c's Avatar
Hello Jason!
You and your wife are fassst! Great job Sunday.
Yeah, I am still getting the hang of driving my truck. -Thank you for the setup help and congratulation on your win and your wife's 3rd place finish. You raced against a fast group of guys, so really impressive run you had.
Hey, shouldn't you be "TeamPink"??!! JK.
tcs in washington subaru73 Northwest Racers 937 08-05-2017 11:18 PM
Tamiya GT Pro Spec Class angrymelon Electric On-Road 15 02-17-2017 10:28 AM
2016 RC Car World On Road schedule RCCarWorld Mid Atlantic RC Racing 971 10-14-2016 07:27 AM
Tamiya Championship Series 2016 TCS Core Creations Nebraska/Iowa Racing 86 03-12-2016 06:37 PM
