Old 12-05-2016, 02:20 AM   #1
Default MOD motor & ESC Fan
Is a fan required on the ESC with a MOD motor? I use a fan for the motor, Reedy 5.5 Thing is, not enough ports on the receiver for everything.
Car is Losi 224, Tekin RSX speedo.
Miko1976 is offline   Reply With Quote
Old 12-05-2016, 02:22 AM   #2
Andy63's Avatar
Yes, a fan on the ESC should always be there. Less heat=less wear and better performence over 5 min.
Cheers// www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 12-05-2016, 02:32 AM   #3
If you're out of receiver ports you can just solder the fan to the positive and negative terminals of the esc (along with the battery wires). This will mean the fan is on whenever the battery is plugged in.
mushroomed is offline   Reply With Quote
Old 12-05-2016, 04:31 AM   #4
massenb203's Avatar
+1
Henry Massenburg
Team C Racing USA, TC10 2015
Ho-B Max RC Park
massenb203 is offline   Reply With Quote
