Bittydesign 1/10 TC 190mm bodyshells!
#332
TQ Racing is also selling Bitty bodies. https://www.tqrcracing.com/shop/prod...asp?p_id=12461
#333
Awesomatix, Yokomo and Xray --> unpacking the M410 body shell 100% Pre-Cut and simply put it over your model. What else? #byebyescissors #JoinTheRevolution #100x100Precut #M410 #ByBittydesign
Available worldwide to local dealers and directly at Bittydesign.net
More models to come in September.
#336
#338
Will other bodies be offered precut or just the M410?
#339
Untitled
Notice I don't scuff the part that sticks out behind the side of the wing;
Untitled
If you're more careful than myself you won't get any air etc trapped behind it like I did
The Shoe Goo fills in the scratches you made and helps make a stronger bond.
Untitled
#341
Regional Moderator
I scuff the end plates with 400 grit wet and dry and then use Shoe Goo, clamp them together overnight.
Untitled
Untitled
Untitled
Untitled
Untitled
Untitled
#342
Shop Owner
I guess the M410 will also fit.
Looking forward to test it, as it looks amazing and hopefully according to testimonies, performs as such!
#343
I always round off the leading upper corner of the wing and endplate so there isn't a sharp corner to catch on the asphalt or carpet.
That does seem to help a lot.
I am expecting to lose one every now and again, but I also had it happen when using tape.
As I mentioned, try to make sure you don't get any air behind it and it should be even better. If you use too much Goo and it squelches out the sides just cut off any excess with scissors etc after it's dried.
#344
Try the Xray T4 version. A friend of mine with TRF419X took a pre-cut IS-200 for my T4 and it fitted as glove. I'm not sure if it's as front as you like though, although my friend was very happy with it
For those who asked: we have not planned to expand the 100% Pre-Cut line also to the others bodies that we do, at the moment only our successfull M410 model will be offered Pre-Cut; September the line will be improved with more chassis, stay tuned
#345
We're sure at 100% that you will be one more to stay speechless after trying the M410 body shell, will be a pleasure to read your feedback here after your test.
