Old 02-02-2017, 04:26 AM   #16
Trader Rating: 114 (100%+)
I personally plan on running a Spektrum A5040 servo. Same servo I'm using in my CRC WGTR car and it works great.
Chris Furman is offline   Reply With Quote
Old 02-02-2017, 08:04 AM   #17
TT_Vert's Avatar
Trader Rating: 68 (100%+)
Originally Posted by old_dude View Post
Not necessarily, His do appear to be close to parallel but that car has a prototype upper hinge pin mount. It all depends on what you want the ackermann to be. I like mine to be swept back from the servo. You will see many variations if you walked thru the pits at a major race.
Is there a happy medium starting point location to fine tune from? I have to start somewhere and I'm not sure where that would be. I do see a mention of flush mounting the front of the case but are the dimension on the front half of the servo case the same so this is a standard distance? Given the wide variety of servo sizes these days I'd have to assume no.
Servo Alignment - Assemble the servo saver, servo saver brace, and ball studs as shown in the diagram. Then when using the two-sided servo tape to hold the servo between the plates, line up the servo case flush with the edge of the graphite plates and this will give you just the right amount of “tie-rod sweep” (steering ackerman).
Dave
TT_Vert is offline   Reply With Quote
Old 02-02-2017, 08:05 AM   #18
Dave
Try everything level.... drive it, then make adjustments from there.
Old 02-09-2017, 05:39 PM   #19
TT_Vert's Avatar
thank you Chris.
