Old 01-08-2006, 08:52 PM   #1
Well i need help on getting a new armature. Because the one that i had got a pebble stuck in it and this is what happened to. it its a reedy flash 15t double modified machine wound motor. I found a hand wound 15t double armature replacement. But its hand wound the one thats in the can when you buy it is a machine wound. Would it matter ?? i dont think it would but let me know.Here is the link to the site that i found that carrys the armature http://www.yokomousa.com/motors/motors.htm (((Scroll to where it says accessories and look for the model number YM-ZAA215 15T Double Armature)))).I also have another problem with the motor cutting when i re-installed the stock 15t motor that came with the tc4 ( it was a RTR kit ) anyways when i give it full throttle it kept cutting out far range and sometimes in close range. So i checked the brushes and the spring compression and there both fine it doesnt cut out when i hold it off the ground just fine but when its on the ground it cuts out let me know how to fix it. And let me know if that armature will work. Thanks a bunch, Dustin
Dustin222 is offline   Reply With Quote
SEO by vBSEO 3.5.0
