Old 11-09-2016, 07:52 AM   #1
Lord_Darkhelmet's Avatar
Default Lipo anti slip tape
Has anyone found a cheap and readily available tape that is a good anti slip material for underneath the lipo? Looking for something thin and light which keeps the battery from moving around. I know Yokomo and Tamiya sell it in short expensive strips lol.
Lord_Darkhelmet is offline   Reply With Quote
Old 11-09-2016, 08:10 AM   #2
SpeedySST's Avatar
Double sided carpet tape maybe?
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 11-09-2016, 08:26 AM   #3
theproffesor's Avatar
Trader Rating: 56 (100%+)
From TQ hobbies the Amani strips are only like 2 bucks. And they work great. You'll only need one per car. I've tried other stuff and nothing works as well. Even if you found the same material on a spool, you will pay way more for the spool that you will never likely use than just a couple strips from Yokomo or Tamiya.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 11-09-2016, 08:32 AM   #4
Just put a little ofna diff lock lube on the chassis, and you're good to go...
bertrandsv87 is offline   Reply With Quote
Old 11-09-2016, 08:36 AM   #5
thin double sided carpet tape works great
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 11-09-2016, 08:41 AM   #6
Rick Vessell's Avatar
It's not permanent, but I use 3M double sided tape. It's used for scrapbooking. There are two kinds, removable and permanent. I use the permanent, it holds the pack well and still comes up when you remove the pack. You can find rolls in 3 packs usually at the craft stores.
Rick Vessell is offline   Reply With Quote
Old 11-09-2016, 01:51 PM   #7
DesertRat's Avatar
+1, good old double sided tape works great. One caveat is that if you are doing this in a touring car with lots of chassis flex you may want to use standard thick servo tape to semi-isolate the pack from the chassis.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 11-09-2016, 09:43 PM   #8
niznai's Avatar
And another vote for double sided tape.
If you use the one that's 1mm thick, that will compensate for flex and allow for the battery not being absolutely flat. Carpet tape is good but ONLY if your battery and substrate (chassis plate) are perfectly flat and free of any contamination. It is also very thin, so it will change chassis flex characteristics.
And one more thing. Go to car part shops and buy the moulding tape or whatever it is called. That is for use on cars on external trim, mouldings, badges, stuff like that. It is weather proof and used in the automotive manufacturing industry, and it will not come off in a hurry. Prices around here are the same as 3M tape, and I have a suspicion it is made by them.
That said, I would recommend using a different system.
I put two vertical round posts at either end of the battery (most chassies already have holes there) and use a strip of filament tape doubled up and stuck to itself and wrapped around a piece of tubing at each end that slides over the posts. This creates a sidewall around the outside of the battery.
The posts can be anything you find lying about the place, provided is round and you can drill and tap a hole down the centre. I used some scrap Aluminium rod, from some old Tamiya car, I think some truck or something, cut to length. It is already tapped, all you need to do is drill a hole across at the top, you'll see further down what for.
On top, I use another strip of tape wrapped at the ends around two flat pieces of thin but hard plastic (bits of an old credit card will do) again doubled up on itself. The plastic bits are just for reinforcing, and are as wide as the tape, and have a hole for the post to go through (a paper hole punch will do an awesome job).
I use two body clips through the posts (this is why you need the hole across the post at the top) to lock in place both the vertical strip that goes around the side and the horizontal piece across the top.
No problems ever, the whole contraption weighs about as much as a bee's dick and lasts forever at a price of maybe 5c.
The battery is free inside this "box" of tape, and the whole bazoonga is anchored to the chassis at only two points (the vertical posts) so flex is not affected in any way.
Most chassies already have the holes for some battery holder system, and recently most have holes for a shorty as well, so no need to drill the plate (I hate that).
I actually use the "normal" length battery holes and add a square piece of foam with wheel balancing weights attached to the bottom with double sided tape to balance the car and/or make legal weight. These are easily removable, and can be tuned to adjust for different conditions. You can also swap the foam piece to the front or rear depending on what weight bias you want.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-10-2016, 04:41 AM   #9
These sound great, but I cant find these on TQ - can you please give a link or part number?
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 11-10-2016, 04:49 AM   #10
Niz, could you post a pic of your system?
Scott, here you go
http://www.tqrcracing.com/shop/produ....asp?p_id=9930
Old 11-10-2016, 05:32 AM   #11
Roelof's Avatar
Send a message via ICQ to Roelof
At the local hardware store you probably can find an anti slip tape used for a stair.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 11-10-2016, 07:44 AM   #12
niznai's Avatar
Here you go.
You can see in this version I didn't even bother with the plastic ends for the top (horizontal) strap but I wrapped the tape around a bit of steel wire. I think it is a bit I cut off one of those long single body clips.
You can also see the little aluminium tubes I wrapped the tape around for the side strap.
Team Greasy Weasel
Old 11-10-2016, 07:58 AM   #13
niznai's Avatar
That is very coarse sandpaper. Literally.
Team Greasy Weasel
Old 11-10-2016, 08:50 AM   #14
This stuff from TKO Competition Development works well for me so far $2.95. I am too new to this forum to post a link but you can google search the website.
baldilox is offline   Reply With Quote
Old 11-10-2016, 08:57 AM   #15
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
here you go baldilox
http://tkocompetitiondev.com/product...nti-slip-tape/
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13563 Today 02:04 PM
Official Xray XB2 2WD Buggy Thread BentKa Electric Off-Road 5001 08-16-2017 11:24 AM
Associated RC 12 R5.2 Blackscale Electric On-Road 1133 08-08-2017 04:53 AM
Team Magic E4 Thread gansei Electric On-Road 4124 02-07-2017 01:09 PM
