Old 11-09-2016, 02:22 PM   #16
bdmpastx's Avatar
Originally Posted by scirocco14 View Post
I too have found that gluing the sidewalls helps, mostly on the front. My *theory* is that it stiffens the sidewalls of the tire, making the effective spring rate on that wheel higher and causing an understeer condition (if used on the front only) which stabilizes the car when it reaches the cornering limit.
The tire sidewall rolls over in the corner and the glue slides on the carpet. It isn't stiffening the sidewall. Real cars do this as well. We just don't put superglue on them lol.
bdmpastx is offline   Reply With Quote
Old 11-09-2016, 02:37 PM   #17
SpeedySST's Avatar
Originally Posted by jlfx car audio View Post
we will see what sweep comes out with for Cleveland champs , but the usgt tire will not change since it's also ran on outdoor tracks
Well Gravity COULD simply make 2 different tires.
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 11-09-2016, 03:25 PM   #18
Location: Beneath a rock down by the river. Don't have money for van
Originally Posted by mooby64 View Post
Is it to let the chassis roll/lean and not lift the inside heels when turning?
It is to make the car roll even more and make it ride on the tires sidewall
Seriously, it's because it will make it less responsive, if the car rolls that much then a bit more of camber gain or higher roll centres would be a better setup direction than gluing sidewall and other voodoo.
( ͡ ͜ʖ ͡)
30Tooth is offline   Reply With Quote
Old 11-09-2016, 03:29 PM   #19
SpeedySST's Avatar
Gluing the sidewalls is no voodoo. It worked like a charm.
Old 11-09-2016, 03:40 PM   #20
Making the tire not ride on the sidewall would be better, imo, but hey whatever floats your goat right?
Making the car roll less wit higher roll centres would make a spring change guaranteed.
No.
I won't go into a full, detailed engineering explanation but a spring's rate simply controls the amount the suspension deflects under cornering and longitudinal acceleration, and thus the body roll angle. The load on the wheel/tire is a function of static load, lateral g-force, wheel track, and CG. The lower the spring rate, the more the suspension deflects and the chassis rolls more. The higher the spring rate the less the suspension deflects and the chassis rolls less. The actual loads on the wheel/tire are virtually unchanged (for a comparable lateral g-force).
If you want the details, check out the book by Milliken & Milliken on Race Car Vehicle Dynamics. It is the bible of race car chassis engineering and analysis. It's only about 800 pages and chock full of complex mathematics...
Tune to Win and Engineer to Win, maybe even Race to Win are also a recommended read preferably before RCVD if you want to retain some sanity.
( ͡ ͜ʖ ͡)
Old 11-09-2016, 05:44 PM   #21
SpeedySST's Avatar
Im pretty sure goats dont float. Boats, however, do.
Old 11-09-2016, 06:42 PM   #22
scirocco14's Avatar
Carroll Smith's books are great, I've had them all for decades. You kind of have to take his word for a lot of his observations though. Milliken & Milliken work you through the math to prove it.
Mark
Mark C. USVTA #115 TC4 & Xray T4 '13, USGT #115 Xray T4 '13
USVTA-F1 #115 F103/4 & F1R3 & WTF1 FC-16. Tamiya M05 M06
Bush River RC, The RUG at King, Ho B Max Raceway, Easley RC
scirocco14 is offline   Reply With Quote
Old 11-10-2016, 12:50 AM   #23
@Mark. Agreed, both have a place in a racers book shelf.
Your Custom Paintjobs charlie_b Painting, Designs, Graphics and Photography 24347 08-17-2017 08:53 AM
RIT DYE a "grey" plastic DX6i to black! targetingxmod Painting, Designs, Graphics and Photography 6 12-09-2015 09:57 AM
Tamiya TC shocks flouring coated, NIP Grey/black MikeXray R/C Items: For Sale/Trade 7 02-27-2012 06:26 AM
MUGEN CARRYING BAG S (GRAY & BLACK) mf305 R/C Items: For Sale/Trade 6 05-25-2010 04:23 AM
Schumacher grey an black TC springs zachtc3 R/C Items: Wanted to Buy 6 05-29-2005 12:04 AM
