13.5t club racing motors
Hi guys, iam new to the forum and need some help on choosing the right motor for the 13.5t club class. Please help. Motors I have in mind are. LRP, ORCA and TEKIN.
My setup: Tamiya trf419x Mamba max ESC GENS ACE 7200 2s 70c lipo |
There are tons of options, Maclan, Reedy, Shuur, Orion, Team scream, LRP, R1, and so on.
Thanks for the reply. Will have a look at them. Iam looking for the best motor possible that wil give me the best performance through out the entire race. Something like the the pros would use.
Trinity D4, either one, max the timing on them and run lower FDR of 4.8, once again watch the motor temp at all times!
Just order a Fantom FR-1 13.5t motor, and look no further...
Originally Posted by NomadRC6
(Post 14726899)
(Post 14726888)
I run the the new tekin gen 3 rpm motors with great success, R1 are very good also, fantom etc. like the post above check and see which motors the majority of the racers at your club are running. And learn how to tune a motor for your track.
I think the ESC might be a bigger problem for you in this case actually. Mamba Max pro is very very large foot print and might cause balance issues. Mamba Max Pro is more designed towards bashing and handle more envirnomental hazards like water and dust. I suggest something more designed towards racing like HW xr10, orca, LRP, etc. The offer more and better tuning options for serious racing.
As for motor the best motor is the motor with the correct spec for the track and class you race in not so much which one pros use or which brand. All the ROAR spec motors are Spec because they have to follow a set of Specs designed to make them all perform with similar overall potential. Things to look for is rotor strength, stack length, rotor diameter, etc that will make that motor perform in the power band you want it to perform at. Best way to know is just see what the local fast guy use as a starting point. |
Watchout... The Local fast guy might be a very slow Worlds guy, so watchout for your current fast Worlds guy instead...lol.....
Originally Posted by bertrandsv87
(Post 14729067)
