Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-16-2002, 11:59 AM   #1
Send a message via AIM to ProRacer03
Default HPI Pro 3 / XXX-S Screw Kits?
Does anyone know how many and which screws of each will replace the stock setup? I want to replace all my screws to hex. I'm buying the screws in bulk so I don't know how many of each i need.
If any of you know how many screws in each kit it would save me a lot of time.
ProRacer03 is offline   Reply With Quote
Old 11-16-2002, 12:02 PM   #2
Sigearhead's Avatar
Trader Rating: 41 (100%+)
A lot of places just sell the complete screw kit and I think that's what most of us have done. You'll just have to get out the manual and start counting!
Sigearhead is offline   Reply With Quote
Old 11-16-2002, 01:50 PM   #3
R/C Tech Founder
Note that the XXX-S already has hex screws, though the Pro 3 does not.
futureal@rctech.net | ampdraw hobbies | ampdraw: power your hobby
futureal is offline   Reply With Quote
Old 11-16-2002, 02:00 PM   #4
Regional Moderator
R/C Tech Charter Subscriber
Rc-Zombies tell you just what you need for the pro 3 in the pro3 forum check it out
Ko Racer is offline   Reply With Quote
Old 11-16-2002, 07:30 PM   #5
Yeah... That's what i was afraid of.. I didn't want to bust out the manual and count but i guess that's what i might have to do.
I knew someone would mention the xxx-s already had hex screws. The only thing is I don't like the screws that come w/ the losi. I'd rather replace them, they are starting to rust on me.
How much do aluminum hex screw kits normally cost?
Old 11-17-2002, 09:08 AM   #6
popsracer's Avatar
Default Aluminum screws
I would stay away from the Aluminum screws. They are much weaker than the normal steel screws in a kit.
Aluminum will break, even in low stress areas in a crash.
Buy Titainium screws instead. Lighter and stronger then steel.
popsracer is offline   Reply With Quote
Old 11-17-2002, 09:47 AM   #7
Evil_S10's Avatar
Send a message via AIM to Evil_S10
I am pretty sure that there is someone on e-bay who is selling a titanium screw kit for the xxx-s. it was like 19 the last time i checked. I could be wrong tho, memory is one thing i am not good at keeping.
Evil_S10 is offline   Reply With Quote
Old 11-17-2002, 02:02 PM   #8
So 7075 T6 Aluminum Screws aren't strong?
Aren't most modified chasis made of the same material?
Also, I want to save weight. I figured I could save weight and still retain most of the strength of the stock screws. I need more opinions
Thanks for the input! I'll look for those titanium screws on ebay.
Old 11-17-2002, 02:46 PM   #9
Send a message via AIM to JeffC
TiR has a really nice titanium screw kit for the xxxs. They've also got a titanium ballstud kit for the xxxs. I'm not sure what their website is, I think the screw kit costs around $70 or so.
JeffC is offline   Reply With Quote
Old 11-17-2002, 02:58 PM   #10
Titanium is cool and all but the price is a little on the high side.
Which was why i was wondering about Aluminum screws.. Do you guys really not recommend T6 Almunium screws because they break easily? Or do they break if you crash hard?
Thanks for the input... Very helpful stuff..
Old 11-17-2002, 06:30 PM   #11
RcTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I know KTHobbies.com has the xxx-s screw kits.
They are nice, I've seen them before, but i still run the stock screws.
-Troy
Troy
#2 RCTech Member
RCDriver Magazine
TSR6 is offline   Reply With Quote
Old 11-17-2002, 07:27 PM   #12
Send a message via AIM to John Stranahan
Default screw strength
Steel screws of the same size are stronger than titanium screws. Stainless screws are a good substitue for steel and provide corrosion resistance. Aluminum screws in a high stress area usally break in half and leave a part stuck inside your chassis usually (cause that's the really expensive part) and ruins the part.
Aluminum screws are much weaker than steel or stainless steel screws. Here are some tensile stregnths for the materials used in screws.
Grade 8 hardended and tempered screw 150,000 pounds per square inch (psi) tensile strength. (Normal screw in a Losi kit(I believe) breaks with a brittle fracture rather than bends)
316 Stainless steel ( a very common stainless alloy) 70,000 psi There are higher strength stainless steel alloys, but they are more brittle than this alloy)
Titanium alloy 6Al-4V (6%aluminum, 4%vanadium) 95,000 psi (Alloy used by Lunsford)
TiSpec alloy used in climbing equipement 65,000 psi
Generic titanium (found in cheaper screws) 35,000 psi
T6 Aluminum Alloy 42,000 psi
nice site to read about the titanium used in climbing equipment
http://www.ushba.com/tifacts.html
John Stranahan is offline   Reply With Quote
Forum Jump
V-one RRR WC Screw kits? LOSI123 Nitro On-Road 2 03-02-2008 05:22 PM
Stainless Screw Kits For Bj4 BCOLEMAN R/C Items: For Sale/Trade 1 04-26-2005 09:09 AM
Rc Screw Kits craig14xxx R/C Items: For Sale/Trade 1 09-09-2003 03:22 PM
Stainless Screw Kits for XXX-S Rob Mincey Electric On-Road 4 07-23-2003 09:34 PM
Stainless Screw Kits quadracing R/C Items: For Sale/Trade 0 05-08-2003 03:58 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
