Old 10-14-2016, 05:28 PM   #31
If using other body shells such as used on Serpent F110, or xray X1, then it should be possible to locate the battery in different orientation to get the CoG further back and still mount the body shell.
UniRacer is offline   Reply With Quote
Old 10-14-2016, 05:28 PM   #32
I prefer the weight being forward: less spinouts.......
bertrandsv87 is offline   Reply With Quote
Old 10-14-2016, 05:34 PM   #33
That's true, but its all relative to which car design you are using and its handling characteristics. There are other ways to tweak the handling balance to create understeer, such as using a bigger rear wing, changing the spring rates, adding a front sway bar, or camber setting adjustment. Which chassis do you base this comment on?
Old 10-14-2016, 06:30 PM   #34
I base it on the fgx with Mckune chassis ....
Old 10-14-2016, 09:45 PM   #35
Have you tried to change to extra hard front springs with heavy weight oil, or otherwise just pack the front shock shafts with rubber O-rings? No matter how good the IRS rear suspension setup is, if the front of the car is too soft and allows the car to roll, its guaranteed to lack stable handling.
Old 10-15-2016, 06:53 AM   #36
I don't have ifs on my fgx, and I am not done building the car yet... I will have to order a new lighter esc, supershorty battery to get close enough to 1050g before racing...
Old 10-15-2016, 09:40 PM   #37
Props to G-rem who did a nice FGX customisation.
3 racing new F1
BCE racing custom chassis thread moparsrule Nitro Off-Road 1979 04-27-2017 02:43 PM
BMI Racing Discussions protc3 Team and Company Discussions 10674 02-05-2017 06:24 PM
On-Point Racing On-Point Racing Team and Company Discussions 402 12-04-2015 02:31 PM
Clodbuster Question muttb0ne Monster Trucks 6 02-24-2013 06:44 PM
TC3 Graphite Chassis, Best Aftermarket model? Cain Electric On-Road 103 04-06-2004 08:13 PM
