KYOSHO INFERNO GT2-VE speed runs
Chassis 299.99
3D bumper - 25
Body - 50
Tires - 50 grp
Esc - 110 mamba monster 2
gears - 35 44 spur 36 pinion (not final)
Motor - 110 poseidon 2200kv
Motor mount - 25 kershaw designs
Servo - savox SAVOX SA-1258TG
Raido - 40 FlySky FS-GT3B 2.4GHz
Gyro - 20 HK401B Gyro
This is my plan for my next RC build. i need some help with gear choice and the smallest spur gear that fits stock is 44 so i have to use that unless you know a way to fit a smaller one. feel free to post any other questions about this car or your version of this car.
Chassis 299.99
3D bumper - 25
Body - 50
Tires - 50 grp
Nice build mine Is almost the same, I have the castle XLX for the ESC and I made the mistake of getting the Leopard 5882 which In the end won't give the needed RPM's to push the car as fast as I want. I ordered a TP Power 4250 and a 5mm 34T pinion, may have to get a bore reducer to see If I can run bigger pinions depending on the motor mount.
i asked bay area fast rc on you tube and he said i should start off with a 25 40 set up and work from there. thanks tho.
DR T what spool is that
In that pic is a 6mm bore Revo spur adaptor on a KYO IG-108 2-Speed Shaft. The KYO IG-108 is just a 6 mm dia shaft replacing the center diff, but you will need the nitro CD top plate and shorter front driveshaft (forgot what part number, just check amain) for that to work as well, or cut the shaft shorter: http://www.rctech.net/forum/14576265-post338.html
I got the spur adaptor from Koval, he makes a lot of cool stuff: http://www.rctech.net/forum/12977946-post124.html, just send him a PM if you want to know more.
I believe RC Monster also sells a modified center diff.
