Painting, Backing Candy colours
When backing a candy colour, do I completely paint the backing silver?
After laying a smooth coat of candy paint, yes, back it with silver.
Make sure to let it fully dry between coats. -Troy |
You can use silver,gold,or even a solid opaque color. Experiment on scrap lexan and you`ll be suprised at what colors you can come up with.
Thanks,
Henry |
I sometimes use different levels of thickness when I use a silver backing. I will go sort of heavy when I want a solid backing or light when I want a sort of see through finish.
Originally posted by STLNLST I sometimes use different levels of thickness when I use a silver backing. I will go sort of heavy when I want a solid backing or light when I want a sort of see through finish. Another thing to remeber when using candy colors is that the depth or thickness of the candy coat will determine what shade the candy comes out. I love candy blue with about 4 fog coats. If you time it right, on the last coat you can giove it just a little more than a fog, but not enough to run and it will make all of the coats lay down quite smooth. Unfortunately, there's quite a bit of practice and timing involved... STLNLST, you never sent me pics of the body!!! :cry: :flaming: L8r doodz |
Thanks again, I'm learning more and more.
Henry |
Anyone else
Good info for the DIY'ers out there:nod:
