Old 10-02-2016, 09:06 PM   #1
Default What adjustments do change first!
Ok guy's,
Just curious on people's thoughts on chassis changes that make the most difference to how a car handles!
I often find myself with a car that when the conditions are right I am not far off the fast guy's and can have .10 -.20 consistency (on really good days) but when track conditions change I struggle to find the right changes to counter those conditions.
I have a list of things I change in order of my percieved top priority first.
1 - Tyres (often controlled but otherwise copy the fast guy's!)
2 - Droop/ride height
3 - Springs
Whenever I change things like shock location, toe, cambers etc I really don't notice any difference, maybe it's just me?
Also when you guy's make these smaller adjustments are you adjusting for better laptimes or better consistency which will lead to better laptimes?
svturtle is offline   Reply With Quote
Old 10-03-2016, 12:12 AM   #2
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Originally Posted by svturtle View Post
Ok guy's,
3 - Springs
Whenever I change things like shock location, toe, cambers etc I really don't notice any difference, maybe it's just me?it you,
Better laptime
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-03-2016, 05:01 AM   #3
Thankyou
Old 10-03-2016, 05:33 AM   #4
1AGOFST's Avatar
Ok guy's,
3 - Springs
A lot of different cars react differently to changes depending on how wide their setup window is. I have driven a car that you can make big changes and had trouble noticing a difference, and others that a small change can definately be felt on track. If you are hitting all corners consistantly lap after lap, then you should feel those small changes. At that point, I go for faster lap times in my setup tuning. Every car will have a sweet spot for those changing track conditions. First identify where the car is losing time (entry, mid, exit), and is it in every corner or just a certain section(tuning for a certain section could lower overall lap time, most time is lost in fast technical sections). Then, make changes based on what and where the car is doing. For me, upper camber link roll center, shock positions, and small camber adjustments are what I usually try. I tune with springs based on how the car is reacting on steering and overall grip mid corner. Not sure about your car, but dont be afraid to play with lower shock positions, they are a huge change compared to upper positions. Same goes for roll center. Roll center change at the inner bottom arm hinge pin is a mych bigger change that camber link changes. And I have found that on the camber link, the inner roll center change is a bigger change than the outside roll center shim. This is just my findings on my ARC R11, like I said, other cars may be more or less sensative. Anither thing we play with is adding or removing chassis stiffeners via top deck posts, top deck to servo mount stiffener, and steering post stiffeners.
Mike Coburn - ARC R11 - RoninRC.com - www.ActivRC.com
Team ARC USA, Team Trinity, Hobby-Authority Distribution, Blitz Bodyshells, Xpert Servos, and the amazing support of my beautiful wife! Please support these outstanding companies!!!
1AGOFST is offline   Reply With Quote
Old 10-03-2016, 06:59 AM   #5
Location: Beneath a rock down by the river. Don't have money for van
That depends hugely on where you are starting setup wise and that's why I've made a small tool to help me on that regard.
( ͡ ͜ʖ ͡)
30Tooth is offline   Reply With Quote
Old 10-03-2016, 09:10 AM   #6
Airwave's Avatar
Airwave is offline   Reply With Quote
Old 10-03-2016, 10:51 AM   #7
Cheers for the replies guy's.
Airwave, that chart is perfect
1AGOFST, i'll take on board your comments about actually identifying where i'm losing the time not just worrying about the overall laptime only.
That combined with Airwaves chart should help out massively.
Oh, and a bit more track time also!
Old 10-03-2016, 12:00 PM   #8
Trader Rating: 28 (100%+)
Order of importance chart...1 being low-7 being high?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 10-03-2016, 12:07 PM   #9
#1 would be the first thing to adjust, it would have the most effect. #2 a little less effect etc.
outlandr91 is offline   Reply With Quote
Old 10-03-2016, 12:23 PM   #10
Got it! Thanks!
Team I'm Over It
Old 10-03-2016, 09:45 PM   #11
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
A lot of having a car you can feel changes in comes down to your preparation and consistency in that preparation. Go on youtube and google jilles groskamp redrc and watch his videos.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 10-03-2016, 11:56 PM   #12
I don't race. But my first adjustment is rear spring preload to control over/understeer.
4roller is offline   Reply With Quote
Old 10-04-2016, 12:34 AM   #13
Airwave's Avatar
spring preload is not a setting. springs should always be free on the shock. Please don't tell me you are using droop screws in the arms to set your ground clearance...
Old 10-04-2016, 01:04 AM   #14
That chart is from the Hudy setup book ;-) But to be honest, it's already quite dated. It still has tremendous value (as does the whole book), but does not reflect how the latest touring cars are setup, e.g. ignoring flex settings and having stuff like gurney strip.
For me the order would be:
1. tires
2. springs
3. oil in shocks and diff
4. droop/rear toe in/flex
5. all the other settings
When the grip changes during the race my best bet would be either stiffer springs or stiffening the car with flex settings.
perzeus is offline   Reply With Quote
Old 10-04-2016, 02:18 AM   #15
daleburr's Avatar
The answer (as always) is "it depends". It depends on:
- What the car is doing
- What I want the car to do
- Where I already am on setup
- Where I'd normally be on setup for the track layout and grip
- How motivated I'm feeling to make time-consuming changes
For example, if the car over-rotates mid-corner then thicker diff oil would help. But if its already a bit loose on corner-exit then that would be a bad idea. So maybe I'd reduce bumpsteer or increase front track width. Unless I'm already low on bumpsteer, and can't be bothered to have the front end apart, in which case I might change springs or chassis flex.
You just need to test, test and test some more. Over the years you'll get a database in your head and a feel for what to change and when. No silver bullets or shortcuts I'm afraid!
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 01:07 AM
What do you change first??? racer53 Electric Off-Road 10 08-11-2011 07:05 AM
What do you tune first? Brushlessboy16 Nitro Off-Road 12 05-02-2011 11:23 AM
How do you "dial your car in?" pakk Electric On-Road 39 07-03-2009 12:24 PM
what do you change up first. Fantomcat Electric On-Road 7 01-30-2006 06:37 PM
