Problems with cut off's
Hello, I have a GT2 with a Hobbywing Max 5 and a Cordova 2400kv. It's a new build and I can't seem to get full power. Also when I give it throttle and let off and try to give throttle again it's dead but then I pull trigger again and it will go. Same w/ braking.. Thanks
Don't know what your issue may be but just check that your transmitter throttle and brake epa are set to maximum travel and that the subtrim is at neutral. Do this first!
I assume the esc would have a setup programming instructions aswell, go through that process.
That should at least set your throttle and brake correctly.
If that doesn't work maybe check sensor plugs, all connections aswell.
Hope this helps.
Hope this helps.
Max 5 cutting off
Hope this helps.
Hope this helps.
No probs, I'd just be swapping out stuff now in the hope of finding the issue! Hopefully someone more knowledgeable can help you out.
Good luck.
Good luck.
