Like Tree17Likes
Old 02-27-2017, 12:43 PM   #121
Professor's Avatar
on another note has anyone tried the option progressive springs ?? what is feel/difference from the standard ones are they worth getting ???
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 02-27-2017, 01:20 PM   #122
Johnny Wishbone's Avatar
I have tried them on carpet, but I prefer the linear springs myself. I think its because I prefer the spring to compress all the way in a linear? feel. The progressive springs have a sort of locked? feel to them on the last part of the compression. I have had decent results with them though, but just seem to end up back with the linear. I think they may not be a bad spring to try in a situation where you are trying to keep the nose of the car off the track, but the harder spring will probably effect the steering as well. Something that would have to be tuned for.
I do like the fact that they sort of fall between the Xray linear springs, but wouldn't mind if the SMJ came a little lighter than whats out there.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-27-2017, 01:35 PM   #123
Professor's Avatar
thanks for the info Gary
Old 03-01-2017, 07:05 AM   #124
Originally Posted by R3VoLuTiOn View Post
Are you running it on black/grey carpet or asphalt? Car has lots of corner speed, I prefer small amounts of droop in 21.5/17.5 classes. I'd say the kit carbon chassis is good for almost everything. Unfortunately I never ran the aluminum chassis, but I imagine it would plant the car a bit, and you'd just tweak a few things to dial it in.
sales@vbcracing.com is the one to use
not yet, haven't needed to retire the D08 from my 21.5 class yet. Are you having any issues with it?
No not all all. I am thinking of buying one. Every man and his dog either have XRAY or Yokomo at my local track. I love the look and quality of the VBC and want something different.
PaulC83 is offline   Reply With Quote
Old 03-01-2017, 09:08 AM   #125
No problem, hope it helps.
The car is of good quality that matches the other brands, just a little cheaper cost on parts. You won't go wrong getting one.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-01-2017, 08:02 PM   #126
if your interested;VBC D06 and D08 F/S
freebird is offline   Reply With Quote
Old 03-02-2017, 07:25 AM   #127
EDWARD2003's Avatar
Hello ya'll, I've done several videos on the D09. I've tried my best to document a ''complete build''. However the videos I've uploaded don't cover a complete build, but rather areas of the build that are necessary to point out.
I hope you enjoy the information and tips.
https://www.youtube.com/channel/UCPs...i28jqQ8iamnMqA
Juniorabca likes this.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 03-05-2017, 04:22 AM   #128
Trader Rating: 16 (100%+)
Looking for somebody to cut shock towers for my DO9 as they are to low for shock travel in VTA.
jtsbell is offline   Reply With Quote
Old 03-05-2017, 07:37 AM   #129
https://www.youtube.com/watch?v=gZwtq1HFE1
The link doesn't seem to work
Old 03-06-2017, 12:15 PM   #130
kewdawg's Avatar
Is anyone using the aluminum rear uprights on their D09?
kewdawg is offline   Reply With Quote
Old 03-06-2017, 08:09 PM   #131
Could you use the D08 shock towers? VBC is running some experimental shock towers but they are only 0.5mm taller than the stock items.
Are you running out of adjustment on the shock collars themselves, as in the springs are too long?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-06-2017, 08:21 PM   #132
I have run them on my D08, using both the 0.0 and the 0.5 uprights and just re-adjusted the arm toe for the built in difference, although the outer 0.5 seem to help the car to corner a little better. I know Dave prefers to run the 0.5 in mod. I also like them because I can set the droop of the flat on the bottom of the upright itself instead of the curved part of the stock piece.
With that said, I still run the D09 stock upright on the D09, mostly because the 2 hole upright is what RC3 settings are based on. I haven't checked but I think there is a difference between the 2 hole locations of the plastic versus the aluminum ones. I'd have to check for sure but I think the inner hole on the plastic is slightly inboard more than the aluminum. (I can confirm that the above hole location difference is correct.)
There should not be any other concerns about using either ones, other than unsprung weight differences, but its pretty small. The car works well with either item. The are quite a bit more durable than some other makes out there as well. I've had mine for a couple years and no twists in them yet.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-06-2017, 08:23 PM   #133
It may be fixed now, as it works for me. Try it again, and if doesn't let Edward know.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-07-2017, 10:47 AM   #134
I cant get the ground clarence below 5.5 mm.
Old 03-07-2017, 11:48 AM   #135
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Just had the best weekend with my D09 yet - its really similar to the previous one. More corner speed and rotation than the '17 xrays I was up against, just needed a bit cleaner driving. All I needed was a bit more dual rate for the extra hard corner rotation, and the rear end stayed planted with less rear droop!
as for jtsbell's ride height issues, how far down are your shock ball ends threaded down on the shaft? is there still visible thread? maybe send us a picture to see what you're working with.
http://i.imgur.com/EW4ZPS8.jpg
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is online now   Reply With Quote
