Like Tree11Likes
Old 01-04-2017, 11:00 PM   #106
Has anyone tried this car out in 21.5 yet?
PaulC83 is offline   Reply With Quote
Old 01-05-2017, 09:33 AM   #107
Akhor's Avatar
Originally Posted by Johnny Wishbone View Post
I have run the plastic parts from the V1, silvers, golds and reds and the durability is very good. I have broken a silver c-hub and steering knuckle, but once I trimmed the DJC stub axle back so it doesn't catch board seems all was well.
I'm not sure if the hard bumper will fit the FF17, but it would be something I'd check into as well.
Parma makes a Hard foam bumper that you can cut to whatever size you want. I highly recommend this product for ANY touring car. You can easily make it fit right to the nose of your body shell and just as wide. Save parts and looks amazing.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 01-05-2017, 01:00 PM   #108
Johnny Wishbone's Avatar
I like using this one.
http://www.vbcracing.com/collections...-b-03-vbc-0079
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-05-2017, 01:02 PM   #109
Is that for a specific class or just that motor? The car performs well in TC 17.5 class.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-08-2017, 05:09 AM   #110
Default D07
I know this is a tread for the D09 . I have a question for the D07 and since most on this tread have been with VBC for awhile is the reason for asking about the D07. I run 21.5 class usgt and I was wondering what chassis should I use. I have the car setup with the v2 aluminum chassis with Ryan Maker default setup. Just need a opinion of what chassis would be suited for this class? Thanks for any input.
bigtee01 is offline   Reply With Quote
Old 01-15-2017, 06:16 AM   #111
Default Ordering parts from vbcracing
Anyone having problems getting parts from VBC racing. Here in USA. placed order like 4 days ago. No tracking # email 2s. No response. Messaged on fb . I got message from someone. From Vbc on fb that they will not address the issue that I am having.
Old 01-15-2017, 06:57 AM   #112
I had an issue and when trying to email support@vbc-racing.com kept getting message kicked back.
I contacted through FB and was refereed to use sales@vbcracing.com
Had a message back next day and replacement parts sent a day later with tracking number. I'd say give that a try.
GimpyGolden is offline   Reply With Quote
Old 01-18-2017, 10:33 PM   #113
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Are you running it on black/grey carpet or asphalt? Car has lots of corner speed, I prefer small amounts of droop in 21.5/17.5 classes. I'd say the kit carbon chassis is good for almost everything. Unfortunately I never ran the aluminum chassis, but I imagine it would plant the car a bit, and you'd just tweak a few things to dial it in.
sales@vbcracing.com is the one to use
not yet, haven't needed to retire the D08 from my 21.5 class yet. Are you having any issues with it?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 01-23-2017, 11:51 AM   #114
Professor's Avatar
has anyone tried the chassis mounted steering as opposed to the floating one on the d09 & if so what differences were noticed
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 01-25-2017, 07:29 AM   #115
Have not run it yet (carpet) but in theory it should take flex out of the front of the car and would be more suited to high traction situations. I would think for asphalt you'd want to stick with the floating mount.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-26-2017, 02:11 PM   #116
Airwave's Avatar
What are the needed parts to mount the direction directly on the chassis?
The user manual point to references I can't find anywhere on Internet.
Are you using D07 parts?
Thx.
Airwave is offline   Reply With Quote
Old 02-26-2017, 03:24 PM   #117
Professor's Avatar
Thx.
there is an option part in the d09 manual for the post but I don't know if they are available in the us, they are not here in aus yet, so I used the ones of 1 of my d08's
hope this helps
graham
Old 02-27-2017, 06:03 AM   #118
Airwave's Avatar
Thx for the answer.
A VBC pilot told me that it is the following part:
WildFireD07/08 Steering Chassis Mounted Post Set D-05-VBC-0177 | VBC Racing
Old 02-27-2017, 08:55 AM   #119
Thx for the answer.
Hope they are correct as those are the ones I got. Pretty sure the swing arm thickness has remained the same, so they should work.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-27-2017, 12:34 PM   #120
Professor's Avatar
part # B-02-G31338 for the chassis mounted steering posts, this is the option in the manual for the d09, but iv'e used the d08 ones in one of my 09's & the work fine
