Like Tree17Likes
Old 12-21-2016, 02:30 AM   #91
Andy63's Avatar
Originally Posted by Professor View Post
What is the advantage/gains in raising the top deck by the spacing as Gary has mentioned ???
If i understand right, by lifting the top deck it can free up it's movement. The flex overall should be more and should work the best outdoors. Even 0.1mm under the top deck makes a huge difference.
If anyone disagrees, then i'm probably wrong!
Cheers// www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 12-21-2016, 11:43 AM   #92
No problem w insert breaking .
Driving 2/ week
the suspension mounts are different as the 08
Originally Posted by 1shnot View Post
Hi guys,
I know not many people have this car yet nor long enough... but anyone having problems with insert breaking with new design hangers? looking to get new sets from D09 to install on my D08.
TIA
Peterke is offline   Reply With Quote
Old 12-21-2016, 03:56 PM   #93
Les
Les's Avatar
[QUOaTE=Peterke;14775483]No problem w insert breaking .
Driving 2/ week
the suspension mounts are different as the 08[/QUOTE]
Hi, how does this car perform, not much information on this forum about handling characteristics.
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 12-21-2016, 07:58 PM   #94
defcone's Avatar
Trader Rating: 15 (100%+)
Driving 2/ week
Cheers[/QUOTE]
Lots of steering and on throttle grip on Asphalt.
defcone is offline   Reply With Quote
Old 12-21-2016, 08:26 PM   #95
Originally Posted by Johnny Wishbone View Post
Playing around with the car more, some more observations.
The assembly instructions suggest a shim between the bearing and the axle in the front hubs. The supplied shims are probably too thick and where causing a slight drag in my car. Took the shims out and this really freed the drive train up.
Check your front bearings...
Gordie
Gordie88 is offline   Reply With Quote
Old 12-21-2016, 09:15 PM   #96
Johnny Wishbone's Avatar
Front bearings are installed correctly. Talking about a steering knuckle change, the molding is slightly thicker between different batches, I'd say about 0.05mm but it was enough to pinch the hex to the knuckle and cause the slightest drag issue. I'm not talking lots here just enough to slow the free spin rotation down.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-22-2016, 07:49 PM   #97
I'm not there yet..
My steering post was slightly to large to fit the bearing had to sand slightly..
Overall so far seems good the kit.
Gordie
Old 12-23-2016, 03:20 AM   #98
TomTurbo's Avatar
what´s the chassis thickness on the d09
2,25mm oder 2,5mm?
thx!
Xray T4 16
Xray XB4 16
TomTurbo is offline   Reply With Quote
Old 12-24-2016, 06:09 AM   #99
LKF
3rd part of the assembly of a vbc d09
The VBC D09 has already got its centerpiece, the drivetrain of the chassis. There are still missing the suspensions and various parts to complete the vehicle. Today it goes on to the beginning with the rear and front suspension.
... more
LKF is offline   Reply With Quote
Old 12-27-2016, 01:44 PM   #100
2,25mm oder 2,5mm?
thx!
Chassis is 2.25mm.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-01-2017, 01:45 PM   #101
Professor's Avatar
Does anyone know if the shock towers of the D09 will fit on the D08 ???
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 01-02-2017, 03:40 PM   #102
If you mean the graphite towers, yes the spacing is the same.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-02-2017, 06:03 PM   #103
Professor's Avatar
yes I did Gary & thanks for the response
Old 01-04-2017, 06:13 AM   #104
daktulos's Avatar
Hi,
Reading from post 1 to the last in this thread what is the general concensus about part durability? What is the weak point of the suspension?
The car I am looking is the new FF17 and it seems to use the same silver plastic parts as the D09...
Thanks!
daktulos is online now   Reply With Quote
Old 01-04-2017, 08:58 AM   #105
Originally Posted by daktulos View Post
Hi,
Thanks!
I have run the plastic parts from the V1, silvers, golds and reds and the durability is very good. I have broken a silver c-hub and steering knuckle, but once I trimmed the DJC stub axle back so it doesn't catch board seems all was well.
I'm not sure if the hard bumper will fit the FF17, but it would be something I'd check into as well.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
