Like Tree17Likes
Old 03-07-2017, 05:50 PM   #136
Trader Rating: 16 (100%+)
Originally Posted by R3VoLuTiOn View Post
Just had the best weekend with my D09 yet - its really similar to the previous one. More corner speed and rotation than the '17 xrays I was up against, just needed a bit cleaner driving. All I needed was a bit more dual rate for the extra hard corner rotation, and the rear end stayed planted with less rear droop!
as for jtsbell's ride height issues, how far down are your shock ball ends threaded down on the shaft? is there still visible thread? maybe send us a picture to see what you're working with.
http://i.imgur.com/EW4ZPS8.jpg
The reason I'm having problems is the VTA tires they are a lot taller than the trueing tires.
jtsbell is offline   Reply With Quote
Old 03-07-2017, 07:27 PM   #137
Johnny Wishbone's Avatar
Yes, realize that. just trying to come up with a solution for you.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-07-2017, 09:26 PM   #138
patorz31's Avatar
Cut 1.5mm off of the shock shaft eyelets. Had to do that with the old D06 and D07 to run vta tires. If you want taller towers contact Paul at Bezerk RC he can build you a set. He built taller sets for guys with the older cars.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is offline   Reply With Quote
Old 03-18-2017, 02:38 AM   #139
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
yep that should do the trick!
I remember the D07 having to do that for yokomo springs
my chassis mounted steering posts should arrive tomorrow, let's see what they do
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is online now   Reply With Quote
Old 03-29-2017, 09:22 PM   #140
Anyone else have trouble with their center pulley shaft being too tight to fit the 3 little bearings over it? I've had to sand it by hand quite a bit and it's still super tight. Any advise?
ChadBlanton is offline   Reply With Quote
Old 03-30-2017, 09:14 AM   #141
I have only built one D09, but had no issues with any of the parts. If your unable to fix it yourself, you should contact VBC about a replacement, they have been pretty good about correcting any issues.
Juniorabca likes this.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-23-2017, 12:48 PM   #142
Airwave's Avatar
I've tried the vertical top deck... How can a such deign work properly???
Seriously, it could have been a good idea, but the design make the car softer... Too soft, that's even dangerous for the belts!
Is somebody using this setup?
Airwave is offline   Reply With Quote
Old 04-24-2017, 08:39 AM   #143
I've run this on a green carpet track and didn't notice any adverse characteristics with it. It definitely produces a lot of torsional twist, but the for and aft stiffness doesn't seem to be effected, the car feels very stiff that way.
Please explain your concerns with the belts?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-24-2017, 08:49 AM   #144
Does the steering feel a little more on the slower side in terms of response using the vertical deck? Does it give more or less steering or no change at all? Curious as to how it would be on low traction asphalt.
PaulC83 is offline   Reply With Quote
Old 04-24-2017, 09:01 AM   #145
Sorry, I can't honestly say that I felt a difference, but this was on carpet.
I probably noticed more of a change in the car, going from the floating steering to the chassis mounted swing arms. The car feels like the steering is more direct this way. I've actually run this on both the D08 and the D09 and its has a better feel all around this way.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-24-2017, 11:16 AM   #146
Airwave's Avatar
I'm gonna try to explain... The vertical top deck is fixed on the rear quite vertically. I mean that the design is going around the spur gear. So if you try to flex the car transversally (bring the front tower closer to the rear tower),you have a lot of flex... It will affect the front belt tension. That, added to the fact that the belt tensioner has been removed, you can have problems with the front belt if you are using powerful motors.
Old 04-24-2017, 01:31 PM   #147
When I installed VTD, I twisted the car in all directions, and didn't notice any more for/aft flex than I have with a traditional top deck. I think because of the way the VTD mounts below the top of the bulkheads helps reduce that flex, that and the VTD being very thick all but eliminates the issue. When I did run it, I never had a belt come off, but I guess it could be possible if hard enough a hit happens. Off course this is JMO, yours may vary.
I did run it at the CDN Nats for a couple rounds and had no issues with it there either.
Ok, I put the VTD back on the car and tried to flex it for/aft, there is about .02mm of flex, but im putting some serious push on the car to do it, so in normal running situation I don't think its going to be a issue. I would watch the front belt though and if you run it fairly loose you'll probably have to notch it up one or two places. Also be wary of the aluminum mounts as if they are loose it will amplify the flex for/aft, my front one was loose and when I snugged it up it took what little flex there was, out.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-30-2017, 06:18 PM   #148
Professor's Avatar
Gary ( johnny wishbone )quote from the d08 thread
There is a D09 Dynamics coming out in May, which usually has a lot of option parts as standard package, sometimes includes both chassis options, all for a really good price.
Gary is this release of the d09 dynamics kit confirmed for may 17 ?? thanks
Graham
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 05-01-2017, 09:13 AM   #149
Graham
Hi Graham, sorry I don't know the hard date, just its suppose to be in May.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-01-2017, 03:14 PM   #150
Professor's Avatar
ok thanks Gary
