Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-15-2002, 06:03 PM   #1
SuperRooster's Avatar
Send a message via AIM to SuperRooster
Default carpet setup for pro 3
hey i am going to be racing carpet racing in a few weeks and i was wondering if anyone knew any good setups for an hpi rs4 pro 3
thanks
SuperRooster is offline   Reply With Quote
Old 11-15-2002, 06:06 PM   #2
popsracer's Avatar
Check the HPI website for set-up sheets. I think there is a carpet set-up there.
popsracer is offline   Reply With Quote
Old 11-15-2002, 06:30 PM   #3
i looked, but i didnt see any carpet setups
Old 11-15-2002, 10:05 PM   #4
There is a carpet setup on the HPI Eurpoe sight. Basicly, what you need to remember is the Pro 3 likes to be setup a little softer than most other cars. If you dont have a top deck though, you dont realy need to bother with setup too much, because the car flexes so much that the chassis twists instead of the suspension compressing, so it will be hard to feel the changes you make.
Cyclonus is offline   Reply With Quote
Old 11-16-2002, 05:50 AM   #5
ok thanks i apreciate it
Old 11-16-2002, 06:01 AM   #6
does anyone else know of any carpet setups
Old 11-16-2002, 09:58 AM   #7
popsracer's Avatar
Default Carpet set-ups
I didn't see a carpet set-up on the HPI site either. One thing is, I'm almost positve that you will need one of the upper deck kits to remove some of the chassis flex if your going to race on carpet. The car will flex too much and be slow in the corners without one.
Old 11-16-2002, 11:46 AM   #8
yes i was planing on buying one im still looking around for the one i want
Old 11-16-2002, 12:00 PM   #9
Sigearhead's Avatar
Trader Rating: 41 (100%+)
http://www.atsushihara.com/setupshee...a_01_04_01.pdf
SuperRooster, go there and use this setup. It works for both rubber tires and foam tires, it's a good setup.
Sigearhead is offline   Reply With Quote
Old 11-17-2002, 09:27 AM   #10
thanks for your help i think im gonna use that one
Forum Jump
carpet setup scjones Corally Product & Tech Forum 1 09-18-2008 12:31 AM
TA-05 carpet setup juanfinesse Electric On-Road 6 11-12-2006 01:33 PM
FT T4 Carpet Setup... StadiumChris Electric Off-Road 3 11-09-2006 08:13 PM
BK2 Carpet Setup HELP please StadiumChris Electric Off-Road 2 04-11-2005 10:26 PM
C4/C4.1 Carpet foam setup? fatdoggy Corally Product & Tech Forum 2 01-07-2004 02:13 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
