Old 01-03-2006, 06:17 PM   #1
Exclamation battery problems, need help!!! plz
hey guys i recently bought a : rc corvette 1/8 scale , and i charge it overnite for 12 hours but in return i only get about 30mins of battery life not to mention that after 10minutes the car begins to lose speed. im not sure how to fix this problem i just have a basic charger and a 12v 800mAh battery.
is there a way to extend the batery life or shorten the charging time, i will purchase sumthing if needed but not too expensive. could you give some suggestions and some links on what to do if possible????
Thanx alot^^
rcorvette is offline   Reply With Quote
Old 01-03-2006, 07:38 PM   #2
i would suggest going out & buying a peak charger that can charge at around 4 amps minimum,5 amps would be ideal. get your self a couple of sport (stick) packs as well. do not let anyone sell you somthing you will not need. just a basic peak charger is all you need.
flysti is offline   Reply With Quote
Old 01-03-2006, 07:49 PM   #3
Soviet's Avatar
He's got a toy...
Sorry brother...thats about the best you can get.
"You don't get hurt racing little cars..."
Soviet is offline   Reply With Quote
Old 01-03-2006, 09:44 PM   #4
thanx for your help flysti
Old 01-03-2006, 10:08 PM   #5
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
It's very hard trying to suggest things with those sort of R/C's, but likewise maybe get yourself an MRC 959 which can charge between 1-8 AA cells. The cells are AA's right? You can also use this charge in the future when you decide to purchase a hobby level R/C. Right now, the 959 is probably overkill, but it will do the job better then anything else (wallchargers etc)
Team Duratrax is offline   Reply With Quote
Old 01-04-2006, 07:22 PM   #6
Stevietd14's Avatar
Send a message via AIM to Stevietd14 Send a message via Yahoo to Stevietd14
30 minutes of battery life with a 800mah battery and a 1/8 scale Thats plenty!...Just get a peak detection charger, and Higher capacity batteries and you will be set.
Stevietd14 is offline   Reply With Quote
BATTERY PROBLEMS!! HELP!! TH691 Electric Off-Road 27 05-09-2007 03:54 PM
battery problems XXXracer Racing Forum 0 06-30-2006 02:42 PM
Battery Problems foaley77 Australian Racing 22 12-20-2004 02:02 PM
Battery Problems! murfy Australian Racing 4 01-14-2004 03:49 AM
Battery Problems lawndoggie Electric On-Road 5 09-22-2003 12:50 PM
SEO by vBSEO 3.5.0
