Like Tree3Likes
Old 02-14-2017, 07:50 AM   #61
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by pphaneuf View Post
And it's also possible that you might need that peak power at a slower part of the track, more than you need top speed on the straight, so that gearing solely on the temperature might not be the best way?
I have had situations where gearing up to reach a maximum allowable motor temperature gave slower lap times than a shorter gear ratio did. It's most common in classes like 17.5/1s 12th scale and 25.5/2s VTA, and very dependent on track layout and ambient temperature.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 05-18-2017, 04:14 PM   #62
I'd like to purchase one but I'm unsure of the options available and what I should be getting. I only do off road buggy for 8th and 10th scale. What would be the best options for me in regards to a flywheel? I do 13.5 and below.
papogator24 is offline   Reply With Quote
Old 05-21-2017, 12:51 PM   #63
The miniPro dyno is great. The reputability is amazing.
papogator24 likes this.
Tom
Xcelerant RC - Dyno Tuning, Custom Motors, Custom Parts
XcelerantRC is offline   Reply With Quote
Old 05-21-2017, 05:59 PM   #64
nexxus's Avatar
Trader Rating: 301 (100%+)
You just need to take out a secured loan on your house to afford one, then another on your car to cover the excessive freight costs.
Bang for buck the Eagle Racing MD2 Dyno does a similar job without ripping your heart out through your hip pocket. The Minipro dyno has potential, but they need to be priced more competitively.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 05-21-2017, 06:39 PM   #65
Riketsu's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to Riketsu
Where do you find the Eagle Racing MD2 Dyno??
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 05-21-2017, 08:41 PM   #66
MD2 was only ever available in Japan AFAIK.
Also is now discontinued. So second hand is the only option.
cplus is offline   Reply With Quote
Old 05-31-2017, 10:28 AM   #67
I just received mine the other day and did a few runs. Still trying to decipher what I'm supposed to be looking at. It looks and feels like a quality product. The owner provides great customer service and helped me solve a few issues. Here's a few runs I did with a 17.5 slingshot paired with tekin RS Gen 2 spec.
Would it be better to also get a motor analyzer to be able to set the amps?
Old 05-31-2017, 10:52 AM   #68
nubs's Avatar
You don't need a motor analyzer to set amps. You just need a DC Am meter. But a lot of companies like Motiv has explicitly stated not to set timing by amp and instead look at temperature and performance characteristics. In other words, amps aren't the end all be all. I don't know if I agree, but that's what they are saying.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 05-31-2017, 11:34 AM   #69
Unspoiled's Avatar
Hi papogator,
Your runs look really consistent. I am surprised by your power and torque numbers. Generally my experience for 17.5 you should see power above 150W and torque around 200.
Do you have your shunt set up for the correct value in the dyno settings? Set by using the dip switches on the back.
Good luck!
AJ
AJ Lorello - Gilbert, AZ
Associated, Hobbywing, Trinity, Airtronics, MKS, Losi, Orion
Unspoiled is offline   Reply With Quote
Old 05-31-2017, 01:13 PM   #70
Originally Posted by Unspoiled View Post
Hi papogator,
Good luck!
AJ
Thanks, that's what Jose at Minipro. We went over the settings to ensure I had it correct and I do. I just need to learn how to play things around. I need to get another flywheel for the lower turn motors.
Unspoiled likes this.
Old 05-31-2017, 01:27 PM   #71
Unspoiled's Avatar
I've talked to Jose a lot. He's great! I was also burned by the same thing!
You should be seeing higher numbers for your torque and power.
Old 06-17-2017, 08:47 PM   #72
tandman's Avatar
Send a message via Yahoo to tandman
Any updates on the minipro dyno yet?? How are you guys making out with results??
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks
tandman is offline   Reply With Quote
Old 07-31-2017, 07:35 PM   #73
Hey sorry I haven't responded. I fried my esc doing a run with my 6.5 and my sensor couldn't handle the high amp draw. Just got a new one but if I want to test motors stronger than 13.5, I have to wait for a sensor with 200 amps that's in the works. The dyno is very accurate and such a neat toy. Unfortunately, I don't run 13.5 class but I haven't had anyone send me a motor yet. I'm way too busy working on my cpa firm and a full time job.
Old 08-03-2017, 05:11 PM   #74
Default esc controller
Hello,
I've just put my dyno together and am trying to get the esc controller working. It seems like I am able to get through the esc calibration, but I don't have a button on the screen that says "activate esc control" like the instructions show.
Is there something I'm missing?
cdub_OffRoad is offline   Reply With Quote
Old 08-04-2017, 06:02 AM   #75
wow, I had sent an email in for support as well, but being after hours, I wasn't expecting a reply. I got an immediate reply!
I'm using a windows tablet to run the dyno, and it has a small screen size. There is a very small button with even smaller arrows on it on the far right of the menu that if you click it, expands out and shows the buttons I was trying to find.
I have my dyno all hooked up and working now.
