Old 09-08-2016, 04:20 PM   #1
Default HOBBYWING XERUN XR10 Pro or Muchmore Fleta Pro V2
which of those two ESC will be the best and more reliable and better peforman for both use in 1/12 and 1/10.
HOBBYWING XERUN XR10 Pro or Muchmore Fleta Pro V2 ????????????
JoseM is offline   Reply With Quote
Old 09-08-2016, 10:30 PM   #2
Well, the HW definitely had zero troubles at the worlds just recently - plus has been out for a while.
Little known about the Muchmore yet (I'm personally about to find out) as it is so new.
Neither are 1S units though, so might not be what you are looking for.
I believe the Muchmore can operate on 1S, but will need a voltage booster.
cplus is offline   Reply With Quote
Old 09-08-2016, 10:36 PM   #3
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
hobbywing works just fine with a booster in stock or mod. hobbywing used to have a 1s dedicated esc and i'm told a new one is planned based on the xr10. no word when that might be available though.
No need to wait though. if you get an xr10pro and run it with a booster, you can always re-purpose it into a touring car later if the single cell version comes out.
you might also have a look at the reedy black box and orca vx3 escs. they both have versions that work natively in single cell.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 09-09-2016, 02:21 AM   #4
pphaneuf's Avatar
The older Reedy Blackbox 410R worked with both 1S and 2S, but the new 510R needs a voltage booster for 1S.
XRay X10'16, Roche Rapide P12-2017, Roche Rapide P10W, Carisma GT24R
pphaneuf is offline   Reply With Quote
Old 09-09-2016, 03:55 AM   #5
dan_vector's Avatar
Trader Rating: 26 (100%+)
I've just got my XR10 pro and I must say I'm very impressed with its smoothness and general feel. I'm coming from the MM Fleta Pro. Get the XR10 I'm confident you'll be very pleased. I've also found the customer support significantly better than Muchmore both remotely and at the bigger races.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 09-10-2016, 04:02 AM   #6
Trader Rating: 42 (100%+)
I use the xr-10 justock in 1:12 with NO booster.
I tested it all the way to a 6.5T mod motor and in 1/12 I had zero issues and no noticable slower servo speed. Even though they are rates 2s.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 09-10-2016, 04:16 AM   #7
RC MARKET's Avatar
2 of best !
RC MARKET is offline   Reply With Quote
Old 11-16-2016, 10:35 AM   #8
Trader Rating: 30 (100%+)
MM Fleta Pro is not new and has been around for a while. Rock solid and smooth as silk. The Fleta Pro V2 has some nice plug in features and again is super dialed.
Norse is offline   Reply With Quote
Old 11-16-2016, 11:22 AM   #9
I personally like the LRP Flow Works team best.
Because of the easy soldering tabs.
And price is much lower around $140,- instead of $200,- for the HW
And no need for program box of around $25,-
Team Associated TC 7.1 - Hobbywing - Ko Propo - Silverback
Capricorn TE03 EVO - LRP - Ko Propo
Cabocuts is offline   Reply With Quote
