Old 01-01-2006, 10:32 AM   #1
Cutting Chassis
Has anyone cut and glued a stock chassis?
Either making it longer or shorter.
My question is what glue was used? and How strong was the joint afterwards?
M2Racing is offline   Reply With Quote
Old 01-01-2006, 12:08 PM   #2
Not a good idea
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 01-02-2006, 10:55 AM   #3
Any suggestions?
Old 01-02-2006, 10:59 AM   #4
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
The suggestion would be dont do it.
XMSRacing is offline   Reply With Quote
Old 01-02-2006, 11:08 AM   #5
DaveW's Avatar
Originally Posted by M2Racing
Any suggestions?
I have done my share of composite chassis cutting... epoxy and CA are your adhesives of choice. Zap makes a great 5 minute epoxy (clear) that can be mixed with ground up composite to further strengthen it. CA of the slow variety should be used for working time, and your primary adhesive. The epoxy is a final adhesive/gap filler. Prep is most important... accuracy is key. It has been done in both on and offroad applications, so strength isnt a problem... as long as you dont do anything that would have broken the original chassis to begin with. Making your cut in an area that has alot of reinforcement will be better in the long run... but makes for a time consuming project. As far as woven graphite plate being cut... i wouldnt recommend it.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
cutting screw holes in chassis protecter film benben10 Electric On-Road 7 07-12-2008 02:03 PM
2.4hz cutting out??? wide_mouth_frog Electric On-Road 9 06-14-2007 05:01 AM
cutting BayArea101 Painting, Designs, Graphics and Photography 11 01-30-2007 01:37 PM
cutting Ti nitrothugg Nitro On-Road 6 03-30-2006 10:17 AM
cutting out??? Greenbox Onroad Nitro Engine Zone 3 09-25-2005 02:23 PM
SEO by vBSEO 3.5.0
