Old 08-23-2016, 07:05 PM   #31
Spec foam tires may not be an answer at this level. There is quite a difference in hardness depending on where the foam is cut on a sheet and from sheet to sheet as well. I know this has been done many times before, but at this level there would be a lot of complaining if one set of tyres is 36 shore and another set is 38 shore. Maybe that amount of difference is acceptable.
ixlr8nz is offline   Reply With Quote
Old 08-23-2016, 07:30 PM   #32
JimmyMac's Avatar
Wouldn't that argument also apply to buying and bringing 30 sets of the same compound/shore of tires to a race?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-23-2016, 11:26 PM   #33
daveaustin5's Avatar
Does anyone know the schedule for the Touring Car event?
daveaustin5 is offline   Reply With Quote
Old 08-23-2016, 11:28 PM   #34
Geberit's Avatar
http://live.liverc.com///355-IFMAR_I...Championships/
Geberit is offline   Reply With Quote
Old 08-24-2016, 02:46 AM   #35
vr01's Avatar
Originally Posted by Bubonic-X View Post
From what I have read some of the speedos they were using (prototypes) were not setup for 3.7v 1 cell use. Using the booster was lighter than a small 7.2v battery pack to power the servo and receiver. Boosters have been around forever since they changed the rule in 12th scale to only use 1 cell 3.7v batteries. They do not put anyone at a disadvantage when used. They are used to boost the voltage from the racing battery from 3.7v to 7.2v which is what a servo and receiver are designed to use.
Just to add that ESC's built specifically for 1S have the booster built in (typically they boost the DC voltage to 6V) which is why you generally don't need a separate booster.
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts, Elangears - Chargers
Team Trinity - BL Motors and Tyre compound,
TQ Wire, RW Racing - Pinions & Spurs
vr01 is offline   Reply With Quote
Old 08-24-2016, 03:07 AM   #36
But such differences , or lets say lack of those differences is up to the agreement with manufacturer chosen. With minimum quality control i should be no problem to obtain almost no noticable differences ( when yo aply your tire additive few minuts earlier it also makes difference)
things like allowable differences in hardness and location of bond between foam layers is just a subject to agreement between organizer and manufacturer.
When manufacturer has a single order of hundreds of sets of same compound and hardness it should be even cheaper for them to manufacture.
From my experience difference in hardness is less important than type of compound ( ex. on some carpets use of rear white tires gives big advantage and going up to yellow makes little difference , but on some carpets this compound family is totally wrong choice due to big tire wear that causes lack of traction at the end of race)
What more in other foam classes that use handout tires at WC or EC they dont complain about any instabilities in quality of tires from set to set.
blazeblazucki is offline   Reply With Quote
Old 08-24-2016, 03:51 AM   #37
hanulec's Avatar
Trader Rating: 27 (100%+)
World's TC track is simply amazing. Wish I went to the event...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-24-2016, 01:43 PM   #38
Schwarta's Avatar
It's a great looking track isn't it!!
Schwarta is offline   Reply With Quote
Old 08-24-2016, 07:24 PM   #39
xevias's Avatar
It was a fun track to drive too.
Wish more Americans made the trip over.
xevias is offline   Reply With Quote
Old 08-24-2016, 07:58 PM   #40
hanulec's Avatar
Watching the day two traction issues/lap time fall off... Boy I'm happy I didnt go!
What a cluster.
I wonder why traction is so inconsistent from run to run when drivers put fresh tires on each time...
Old 08-24-2016, 08:01 PM   #41
Trader Rating: 20 (100%+)
Looks like a seriously windy day may have caused the traction issues.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-24-2016, 08:10 PM   #42
Trader Rating: 23 (100%+)
If the soda they sprayed never has a chance to get heated and with wind blowing - it will glaze and lose bite. I am not familiar with the 'Traction Oil' that they are using but if it is for foam, like Tweak, it will be much better during a sunny day.
Bruno seems dialed in high bite and low bite.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-24-2016, 09:58 PM   #43
The sun came in and the times dropped!
Surprise of this round - Viktor Wilck. Nice run.
Shock of this round - Tamiya moves down.
The would-be B sort is looking pretty fierce.
TEAMORCA.SHOP
Old 08-25-2016, 06:05 AM   #44
They mentioned that it was sugar water in the broadcast yesterday so I'm not sure if they are spraying sugar or pop. They did say that they prep the night before which isn't good IMO, too much dust and I don't think it will set up very well at night with cooler, damper air.
Should be interesting qualifying with some of the heavy hitters in the B-sort for sure.
Old 08-25-2016, 06:12 AM   #45
"After this morning’s low traction following the sugar watering IFMAR called a team managers meeting where it was agreed that the procedure would be conducted each morning albeit at an early hour." [Source: events.redrc.net/2016/08/coelho-takes-opening-qualifier-at-wc/]
ishiba is offline   Reply With Quote
