Xray T4'17
#1366
#1368
Graphite Chassis (XRA301142)
Servo mount (XRA306204-O)
Servo holder floating (XRA306233)
Motor mount (XRA303067-O)
Layshaft bulkhead (XRA303066-O)
Motor Mount plate (XRA303068-O)
And if you want the chassis brace
Graphite chassis stiffner (XRA306530)
You can put your own turnbuckle chassis stiffner together if you want that.
#1369
#1370
Hope this helps.
What's NEW at T4 2017?
- NEW chassis plate (2.2mm Carbon, with recording for the new motor mount)
- NEW Motor holder
- NEW Motor holder plate
- NEW center shaft holder
- NEW Floating Servo Mount
301142 T4'17 CHASSIS 2.2MM GRAPHITE
301143 T4'17 ALU CHASSIS 2.0MM - SWISS 7075 T6
301144 T4'17 ALU FLEX CHASSIS 2.0MM - SWISS 7075 T6
302536 ALU STEERING POST FOR FLOATING SERVO SAVER (2)
303066-O T4'17 ALU LAYSHAFT BULKHEAD CLOSED L/R - ORANGE
303067-O T4'17 ALU MOTOR MOUNT - ORANGE
303068-O T4'17 ALU MOTOR MOUNT PLATE - ORANGE
306204-O T4'17 ALU SERVO MOUNT - ORANGE
306233 T4'17 GRAPHITE FLOATING SERVO HOLDER 3.0MM
306530 T4'17 GRAPHITE CHASSIS STIFFENER 3.0MM
#1371
Does anyone know of a good alternative to the front ECS driveshafts?
#1372
#1374
The Xsquare ones from RC Mart get my vote, had two pairs for almost a year and no issues at all. Plus they have clips
http://www.rcmart.com/spring-steel-x...=595_1077_1571
#1375
#1376
Only ever run 52mm's in the front, so can't really comment on the length difference.
#1377
Thanks, the X-Square ones look good and I much prefer the clip design.
#1378
, ,(XP-20002) by X-Square Spring Steel Double Joint Driveshaft 41mm
The original Roche ones are a similar design and were mega, I've got a set that are about 3 years old and still going strong in my wet car now. The newer Radtec ones are not quite so good, the tolerances have drifted. Still strong though.
#1379
Interesting; at $26 shipped they're basically disposable, so as long as they don't fail on track they look a good option.
#1380
