Old 12-12-2016, 06:20 AM   #586
pphaneuf's Avatar
Originally Posted by jiml View Post
Meanwhile on the 21.5 is the new stock thread, people are looking forward to 21.5 12th scale.
Can a pinion big enough be fitted? Will it touch the ground?
XRay X10'16, Roche Rapide P12-2017, Roche Rapide P10W, Carisma GT24R
pphaneuf is offline   Reply With Quote
Old 12-12-2016, 07:27 AM   #587
hanulec's Avatar
Trader Rating: 27 (100%+)
Jim.. stock 1/12 aint broken (but handouts motors could help it). Let's keep this modified focused..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-12-2016, 07:39 AM   #588
Roger that!
jiml is offline   Reply With Quote
Old 12-12-2016, 03:45 PM   #589
Originally Posted by sdunnmcp View Post
Blinky open motor was great at the Champs. I thought it had good speed and cars were easier to drive. It is still difficult, but I think with this configuration, it is achievable.
Steve
Hi Steve. What motor combination did you drive? Glad to hear your honest comment about these rules.
davidl is offline   Reply With Quote
Old 12-12-2016, 06:23 PM   #590
I ran a Motive 3.5 with 88/28 gearing and 30 degrees of timing. The only place you don't feel the crazy speed is on the straight. The infield may be a touch quicker with Blinky.
Steve
sdunnmcp is offline   Reply With Quote
Old 12-12-2016, 06:40 PM   #591
Steve
That is pretty cool. And to think that you and I had major disagreement about timing boost 10 years ago. We may actually still have that disagreement, but good to hear your honesty.
Old 12-13-2016, 01:52 PM   #592
CypressMidWest's Avatar
Originally Posted by Racermac73 View Post
Ive seen a lot of guys say they will quit 12th scale or rc in general if 12th goes to rubber tires, or if mod becomes blinky, or if bodies are changed, or whatever.. i just want to be the first to say fu@k it. I'll still be racing long after these rule changes and still having fun
I feel ALMOST the same way. I said I wouldn't run 17.5 at big races anymore and I don't. I wasn't a proponent of SPEC tire, but that's because they don't work at all on grey carpet. Since almost every track and EVERY big event has black carpet now, that debate is dead. Bodies have changed, and I think Josh Cyrul makes some fantastic sense in his point that we should lower the overall downforce levels and make drivers lift off throttle again. But I do believe that rubber tire 12th scale is just stupid. Single biggest class at The Champs was 17.5 12th. No need to try and fix a class that CLEARLY WORKS already.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-13-2016, 11:21 PM   #593
No Problem. I think we all saw, that timing in mod on US tracks was a little too much. Hopefully we don't see 9000Mah packs anytime soon as this will cause us to run 3.0 or 2.5 turn motors and put us back to were we were. Today if we had anymore motor with 8000Mah packs I think we would dump, I was close on some runs but probably due more to my bad driving.
Steve
Old 12-13-2016, 11:37 PM   #594
8up
Default mini motor
Years ago i put an 1/18 brushless setup on my 1/12 scale just for giggles.
I used a castle 8000kv sidewinder micro and a 2200 mah 2 cell from my kids rc18b.
The car was crazy light. Just a bit over 20 oz. Springs and tires were way off.
However the super light car had a magic feel to it.
Also didn't smack the boards as hard either.
Brakes on the other hand.... none LoL.
Instead of power limits on the motor, what about a physical size limit. Just like real F1
Maybe a slightly larger diameter motor like the 1/16th sized stuff would have better braking?
8up is offline   Reply With Quote
Old 12-14-2016, 01:53 AM   #595
EDWARD2003's Avatar
This past Monday I was practicing at Yatabe Arena with my 21.5/2s 1/12th setup. I was on the track with other 1/12th scale cars running 6.5/1s. I couldn't believe the speed difference between the two. I was easily chasing down and passing 6.5/1s.
I think 30.5 would be a better motor choice if those who do decided on running a 2s setup.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 12-14-2016, 04:19 AM   #596
antlockyer's Avatar
21.5/2s blinky is your stock class and open mod is the other class right? Where the 6.5 guys running blinky?
antlockyer is offline   Reply With Quote
Old 12-14-2016, 04:56 AM   #597
EDWARD2003's Avatar
Yes, 21.5/2s is our stock racing class and it's fast. Transitioning from stock to modified isn't a huge jump. However, starting out is a relatively big jump, but you can decide on your speed until you feel comfortable to go all out.
There's a race series called Electric Pan Car Series that follows ROAR rules.
                 VBC 12M - D08 - FX
Old 12-14-2016, 05:54 AM   #598
antlockyer's Avatar
Interesting, thanks.
Old 12-14-2016, 07:42 AM   #599
DesertRat's Avatar
I may have noted this in this thread before but I think I found a quick way to make even the hottest modified motor driveable by any decent stock racer with a quick trigger finger:
Go into your radio's Speed setting that mostly nitro racers use to slow down servos and prevent flame-out, select the throttle + direction, and adjust it to -30 (that's a good start on my Sanwa MT-4) or whatever slows your throttle to take 0.4 seconds or so to go from neutral to full power.
All of the sudden, your undriveably powerful Mod is driveable, even if your fists are made of ham.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-14-2016, 12:20 PM   #600
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Thats a good idea! Ive been using the xr10prossoftening feature which has a similar effect though not as brutal as lowering punchrates. Honestly i dont think limiting things will make mod any more desireable. People just need to try it out and dicipline themselves to practice throttle control.
After running 6.5 and 3.5 boost back to back, 6.5 was easier to drive in the corners for sure with less slowing down, but in a race on track, the two weren't that different in laptimes. Of course im not hebert, most of us prob arent heh.
I will say with the new carpet at least, 6.5 with stripes is perfectly reasonable coming from 13.5. I made no setup changes to the car, just dropped a 6.5 in. Even ran the same strakka.
Even for full open, tires seem to be easier to manage. Just my experience though.
valk is offline   Reply With Quote
