XRAY X12 2017 1/12 Pan Car
#61
If so, remove all of them
#62
I take out all the shim the ride height now 4.8mm
I change the shims on the kingpin
the 4x0.2mm and 0.5mm shim the manual say place on top off the steering block
I put them now down the steering block
#63
Also to fine tune the ride ride height, you can put the kingpin spacers that are above the steering block and move them underneath the steering block which will lower the ride height as well.
Know that both these things affect the roll center and camber gain (kingpin shims) of the front end.
#64
its strange if you buy a new kit and you cant adjust the ride heigt to 3mm
whit 42mm diameter front wheels
#66
the manual say 43mm front tyer 0.6mm shim under the lower arm
ride height 3mm ???
but what tire diameter do you guys running front and rear
whit 13.5 turns blinky
when I go 40mm front and 41 back
what its the life time off the tire
ride height 3mm ???
#67
The surface you race on mostly determines the size of the tires you should run. The more grip you have, the smaller the tire. More grip also lessens tire wear. It is a balance between car handling and lifetime of the tire. For club racing you might choose to use slightly larger tires, for a bigger event you might want to use smaller tires.
Bigger tires tend to 'chunk' more .. ruining the tire.
Also know that some rims are not the same diameter, for instance .. a Jaco brand front tire cut to 41mm has more foam then a CRC/BSR tire cut to the same size. The amount of foam on the tire is what we care about (it affects handling).
If club racing on carpet try 41.5 fronts and 42mm rears .. pay attention to when your car feels the best and note the tire size.
My preference for club racing:
CRC Grey Carpet - 41/42
CRC Black Carpet - 40/41
#68
With your 42mm tyres, what is the ride height with all three colour spacers under the front arms? (that should be 1.2mm of ride height spacers)
#69
truggy100 just for your reference I was running 39.6mm tyres (Jaco) with over 3.3mm of ride height this weekend.
#72
Looks like they're IRS. I've had mine a few years.
http://www.actionmodelcentre.com/pro...?prod=IRS-3020
#73
I haven't seen a team sheet with less than 3.2mm
I would suggest one of two options;
You could buy another set of ride height shims and use some of those to lower the ride height (I bought spares in case I lost any etc)
True your tyres down further to 40.6 etc like most team driver setups, which should at least get you closer.
I struggled several times at the worlds to make ride height as the fronts were getting hammered in each run.
#75
thanks guys for all the advise
I put for now some extra shims under the arm
how you find whats the good tire diameter ????
