    Hide Wikipost
Old 03-17-2017, 02:50 AM   -   Wikipost
R/C Tech Forums Thread Wiki: XRAY X12 2017 1/12 Pan Car
Last edit by: R Dodge
Welcome to the XRAY X12'17 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. Many of us run the X12'17 on high bite carpet and with most US tracks going to the new black CRC carpet, most setups from here out will be developed for those high bite conditions.
Tips & Tricks:
Some racers notice slop developed in the front end over time. One method to reduce/remove this, as pointed out by some of our friends in Europe is to score the inside of the plastic front pivot ball (where the kingpin goes through) with a sharp xacto blade. Usually 4 scores at 12, 3, 6 and 9 will do. Alternative options can be found listed below.
As with any 1/12 pan car, a smooth operating suspension is critical to performance. It is recommended to polish your kingpins & hinge pins using a dremel or a drill and some sort of polish (IE Gravity polish or Mothers Aluminum polish will work). If you find that your suspension has a bind, you may look at using a reamer or drillbit to make sure the holes are clear of any flashing or debris. The only place this may happen is at the upper hingepin, which is 2mm dia.
For stock racing we usually find ourselves looking for a little more steering. One trick that some of the stock drivers have done that seems to help is lowering the graphite plate that the servo & shock mount to. To do this, you will need the 17mm standoffs from VBC and the servo mounts from the 2015 or earlier X12. Be careful that the servo mounts do not sit crooked on the plate when attaching it; a 0.2-0.5mm shim will help ensure it sits perfect on the graphite plate. Part numbers can be found below.
Option Parts to consider:
XRA371220 X12 Foam Bumper
XRA372012 Composite Front Upper Arm Mount – Right – Graphite
XRA372022 Composite Front Upper Arm Mount – Left – Graphite
XRA372113 Composite Suspension Arm Front Lower – Right – Graphite
XRA372123 Composite Suspension Arm Front Lower – Left – Graphite
XRA372177
Spring 4.75 Coils 3.6x6x0.45mm, C=2.0 - Silver (Soft) (2)
XRA372178
Spring 4.05 Coils 3.6x6x0.45mm, C=2.5 - Black (Soft) (2)
XRA373584 Side Spring C=0.6 - Silver (2)
XRA373586 Side Spring C=1.2 - Black (2)
XRA375010 Graphite Rear Axle Shaft - highly recommended
XRA378094 Shock Spring C=2.1 – Black
Lowered Graphite Plate:
B-02-VBC5005
XRA376255-O Alu Servo Mount - Orange (2)
Front end options:
ASC4403 Kingpins, 1:12 Scale
ASC4622 Upper Arm Eyelets
ASC4626 Upper Arm Mounts/Steering Blocks
ASC4627 Front Axles
ASC8417 Pivot Balls
Aluminum Chassis:
Max.FX Aluminum Chassis
McFactory Motorsports
Reflex/RSD
Recent Setups:
Alexander Hagberg - Snowbird Nationals - Mod - High Bite
Craig Xavier - Snowbird Nationals - 17.5 - High Bite
Robbie Dodge - Snowbird Nationals - 17.5 - High Bite
Eric Anderson - ROAR Carpet Nationals - 13.5 High Bite
Print Wikipost
Like Tree4Likes
Old 10-04-2016, 02:20 AM   #46
R Dodge's Avatar
X12'17 Manual Update - Rear Axle shimming
https://www.teamxray.com/teamxray/ne...59735da24847f8
XRAY X12 2017 1/12 Pan Car-show.php.jpg
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy★
R Dodge is offline   Reply With Quote
Old 10-05-2016, 02:50 PM   #47
R/C Tech Founder
R/C Tech Charter Subscriber
Originally Posted by Fastforward View Post
Where can I buy one and what is the price?
We have a (very) limited number of T4 2017 Kits and X12 2017 Kits available directly from the IIC here in Vegas.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 10-07-2016, 09:50 AM   #48
iam bulding the x12 2017 but the front its slopy from new
when you use the graphite suspension parts
do you have then less slopy front end ???
truggy100 is offline   Reply With Quote
Old 10-07-2016, 10:25 AM   #49
antlockyer's Avatar
Not on my 2016 no.
antlockyer is offline   Reply With Quote
Old 10-08-2016, 08:18 AM   #50
haywood's Avatar
Trader Rating: 48 (100%+)
Default X12 2017
Here is a picture of my buddies 2017 build in progress. As far as the slop in the front end goes you can eliminate it by using a combination of Xenon or Associated parts.
XRAY X12 2017 1/12 Pan Car-49757569518__dc3e80a6-9dbf-4b8d-b50d-69fdb46421a6.jpg.jpeg
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 10-08-2016, 08:37 AM   #51
can you tell me whit parts you change in the front end
Old 10-08-2016, 12:42 PM   #52
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Sad to see the new front end parts is still sloppy. Was hoping to purchase those parts for my 2016.
Dan is offline   Reply With Quote
Old 10-08-2016, 01:26 PM   #53
Trader Rating: 24 (100%+)
Me too. Was hoping they could figure it out but I guess not.
fenton06 is online now   Reply With Quote
Old 10-08-2016, 02:29 PM   #54
miller tyme's Avatar
I heard all the gripes about slop but I built mine per the kit and my front end feels just as good as any other one I've built (and there have been a few )
Ken Miller
RC America - X-Ray - ORCA - EA Motorsorts - Pro Level RC - Sanwa - TQ Wire - ProOne Racing Tires -
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 10-08-2016, 09:55 PM   #55
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Teameam.com has some.
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 10-10-2016, 05:23 AM   #56
i have some problem whit the front right high off the car
I build the car as the manual frontspring and shims off the kingpin
my front tyer diameter its 42mm but I can not lower the reight high of 3.4mm
I put all the reight high shims under the arm
what do I rong ???
Old 10-10-2016, 05:40 AM   #57
antlockyer's Avatar
Put the shims under the steering block?
Old 10-10-2016, 05:41 AM   #58
the you olso change the camber gain
Old 10-10-2016, 05:57 AM   #59
Skiddins's Avatar
what do I rong ???
You need to remove the ride height shims to increase ride height, not lower it
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 10-10-2016, 07:43 AM   #60
yes I now
but I whant to decrease the right height
I want to run 3mm front ride height
I have 42mm diameter wheels
and put all the shims under the arm the ride height now 3,4mm
I think I need to order more ride height shims
