XRAY X12 2017 1/12 Pan Car
#31
The other screw that undoes a lot on mine is the right hand shock tower one. Replaced the aluminium one with steel to see if that helps.
#33
Got my kit yesterday. But the rear pod seems to have a rather interesting deisgn (see pcitures).
I would at least expect xray to include one single 5mm spacer that makes for a symmetrical track width...
#34
Everyone like a different track width, so I wouldn't expect them to include spacers. Wheel offsets are different so it would be tough to cover all the bases.
#35
It's like they moved the left pod plate by 5mm and forgot to space the left hub back out. Even one of the photos on the X12 web page shows the wheels offset differently! Not good.
#36
Suspended
While I agree that a 5mm spacer to make up for the 5mm that was removed would be nice, this is addressed in the manual and there are various width shims in the kit. The shims in the kit should be sufficient for most offsets.
#37
Almost ready;
I think I have 6mm more spacers on the left rear than the right to make the track even on both sides.
I measured from the small balancing hole in the centre of the rear pod.
#38
What's the 17 kit weigh in at compared to the 16 kit weigh in at? Still super heavy?
#39
#40
Suspended
I don't have exact numbers, but we are finding that the '17 is a bit lighter than the '16 for the reasons Skiddin's mentioned. Even with an aluminum chassis, we are seeing the '17 come in under 730.
EDIT: This is with the graphite axle and aluminum hardware at least on the top of the car.
Last edited by R Dodge; 09-29-2016 at 10:39 AM. Reason: Details added following Craig's post
#43
#44
What bumper is that? My son ran his for the first time last Friday, unfortunately the front end is still sloppy
#45
It's an old CRC from when I first raced 1/12
