    Hide Wikipost
Old 03-17-2017, 02:50 AM   -   Wikipost
R/C Tech Forums Thread Wiki: XRAY X12 2017 1/12 Pan Car
Last edit by: R Dodge
Welcome to the XRAY X12'17 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. Many of us run the X12'17 on high bite carpet and with most US tracks going to the new black CRC carpet, most setups from here out will be developed for those high bite conditions.
Tips & Tricks:
Some racers notice slop developed in the front end over time. One method to reduce/remove this, as pointed out by some of our friends in Europe is to score the inside of the plastic front pivot ball (where the kingpin goes through) with a sharp xacto blade. Usually 4 scores at 12, 3, 6 and 9 will do. Alternative options can be found listed below.
As with any 1/12 pan car, a smooth operating suspension is critical to performance. It is recommended to polish your kingpins & hinge pins using a dremel or a drill and some sort of polish (IE Gravity polish or Mothers Aluminum polish will work). If you find that your suspension has a bind, you may look at using a reamer or drillbit to make sure the holes are clear of any flashing or debris. The only place this may happen is at the upper hingepin, which is 2mm dia.
For stock racing we usually find ourselves looking for a little more steering. One trick that some of the stock drivers have done that seems to help is lowering the graphite plate that the servo & shock mount to. To do this, you will need the 17mm standoffs from VBC and the servo mounts from the 2015 or earlier X12. Be careful that the servo mounts do not sit crooked on the plate when attaching it; a 0.2-0.5mm shim will help ensure it sits perfect on the graphite plate. Part numbers can be found below.
Option Parts to consider:
XRA371220 X12 Foam Bumper
XRA372012 Composite Front Upper Arm Mount – Right – Graphite
XRA372022 Composite Front Upper Arm Mount – Left – Graphite
XRA372113 Composite Suspension Arm Front Lower – Right – Graphite
XRA372123 Composite Suspension Arm Front Lower – Left – Graphite
XRA372177
Spring 4.75 Coils 3.6x6x0.45mm, C=2.0 - Silver (Soft) (2)
XRA372178
Spring 4.05 Coils 3.6x6x0.45mm, C=2.5 - Black (Soft) (2)
XRA373584 Side Spring C=0.6 - Silver (2)
XRA373586 Side Spring C=1.2 - Black (2)
XRA375010 Graphite Rear Axle Shaft - highly recommended
XRA378094 Shock Spring C=2.1 – Black
Lowered Graphite Plate:
B-02-VBC5005
XRA376255-O Alu Servo Mount - Orange (2)
Front end options:
ASC4403 Kingpins, 1:12 Scale
ASC4622 Upper Arm Eyelets
ASC4626 Upper Arm Mounts/Steering Blocks
ASC4627 Front Axles
ASC8417 Pivot Balls
Aluminum Chassis:
Max.FX Aluminum Chassis
McFactory Motorsports
Reflex/RSD
Recent Setups:
Alexander Hagberg - Snowbird Nationals - Mod - High Bite
Craig Xavier - Snowbird Nationals - 17.5 - High Bite
Robbie Dodge - Snowbird Nationals - 17.5 - High Bite
Eric Anderson - ROAR Carpet Nationals - 13.5 High Bite
Print Wikipost
Like Tree8Likes
Old 09-02-2016, 07:15 PM   #16
Originally Posted by fenton06 View Post
Did they make any changes to the main chassis?
I'm guessing yes. Need to make a real reason for people to upgrade or force one by making sure it's not backwards compatible
cplus is online now   Reply With Quote
Old 09-10-2016, 04:12 AM   #17
RC MARKET's Avatar
XRAY X12'17 New parts
371107 X12'17 GRAPHITE CHASSIS 2.5MM
371153 X12'17 GRAPHITE 2.5MM REAR POD LOWER PLATE
372150 COMPOSITE FRONT UPPER BALL JOINT (2)
373014 X12'17 ALU REAR BULKHEAD - MOTOR (RIGHT)
373024 X12'17 ALU REAR BULKHEAD - LEFT
373033 X12'17 GRAPHITE REAR BULKHEAD BRACE
373085 X12'17 REAR BRACE - GRAPHITE 2.5MM
373549 X12'17 REAR POD UPPER PLATE - GRAPHITE 2.5MM
375031 X12'17 ALU REAR WHEEL HUB - RIGHT
375051-O X12'17 ALU DIFF HUB - ORANGE
RC MARKET is offline   Reply With Quote
Old 09-11-2016, 10:28 AM   #18
RC MARKET's Avatar
This is 17 Kit?
XRAY X12 2017 1/12 Pan Car-14249925_1400717276623813_7457303726718290742_o.jpg
Old 09-11-2016, 03:14 PM   #19
Certainly is. A pair of 2017 models.
Old 09-12-2016, 09:43 AM   #20
Any news on the release date?
niemand is offline   Reply With Quote
Old 09-15-2016, 02:11 AM   #21
R Dodge's Avatar
Should have some info from Xray very soon. Probably sometime next week, or earlier if we are lucky. I know they are working on it.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 09-15-2016, 02:20 AM   #22
pphaneuf's Avatar
Originally Posted by Zerodefect View Post
Hint: Exacto knife. Or just upgrade to the steel balls.
http://forum.teamxray.com/viewtopic.php?f=24&t=18988
Even with that trick, it's no Xenon front end... Slop doesn't come only from the composite ball, and that composite ball is also supposed to let the kingpin slide more smoothly.
XRay X10'16, Roche Rapide P12-2017, Roche Rapide P10W, Carisma GT24R
pphaneuf is online now   Reply With Quote
Old 09-22-2016, 03:47 AM   #23
Skiddins's Avatar
It's out
https://teamxray.com/x12/2017/en/
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-22-2016, 06:31 AM   #24
antlockyer's Avatar
That pod fixes the things I don't like about mine.
antlockyer is offline   Reply With Quote
Old 09-22-2016, 03:21 PM   #25
Ie: the motor shifting in a mild shunt no matter how tight you torque the screws down?
Old 09-22-2016, 09:44 PM   #26
Yes the motor shifts/moves to easy after a small tap.
West Coast R/C Works
West Coast R/C Works Shapeways Store
LRP America
Ulti Tires
silden is offline   Reply With Quote
Old 09-22-2016, 10:39 PM   #27
Trader Rating: 24 (100%+)
I switched to flanged Kyosho screws that use a 2.5mm driver and that was the end of my motor moving problem. ( I probably also hit less stuff as I drove the car more.) That said, I am excited to see they added a 3rd screw. Looking forward to getting one when the funds allow. Maybe January...
Side question: Will XRAY be offering an aluminum chassis? I seem to remember seeing a picture floating around somewhere...
fenton06 is offline   Reply With Quote
Old 09-22-2016, 11:08 PM   #28
Yes they do and a aluminum pod too.
The order numbers are 371108 and 371254 for the pod.
I'll post a couple photos after I build it. which is next were hopefully.
LRP America
Ulti Tires
Old 09-23-2016, 12:51 AM   #29
antlockyer's Avatar
I had several meetings ruined with motors moving and then found out there was a replacement part that solved the issue (3.2mm slots on the old bulkhead replaced with 3mm slots) I got one and used it with several crashes (including a vicious take out on the first lap of the final that broke my rollover mast) the motor moved the tiniest amount if at all.
The thing I really dislike is the alu brace, I find the diff side nut undoes and it is a pain having to take the axle out to fix it at a club meeting where I already don't have enough time between heats.
Old 09-23-2016, 02:09 AM   #30
Skiddins's Avatar
Had that happen at the worlds mid run, jammed the diff and cost me a run.
Not a problem any more
Xray X12 2017
Xray X1'16
RCDisco.co.uk
