Old 12-30-2005, 04:27 AM   #1
MAD916's Avatar
Default Servo Savers or Not???
Just wondering what everyones opinion is on running Servos Savers on your 10th T.C.
We lost a brand new KO 2123 after just a couple hits. It was a first try without a Saver. I sure see a lot of the "Fast Guy" running without... but hate to toast another servo.
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 12-30-2005, 05:37 AM   #2
Charles Godwin's Avatar
I've been advised to use a servo saver indoors and if the curbs/corners outside are not to dangerous you can get away with a normal servo horn
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-30-2005, 06:15 AM   #3
Trader Rating: 21 (100%+)
I haven't used a servo saver for many years on my TC. I used to use them but I noticed that the springs in the savers wear out in time and then your steering trim is always off. I guess that means I got to be a better driver by using a direct servo horn, hahaha. But yea, if you are still tapping walls, boards, other cars, then I would still use them. The best one I used before was Kimbrough(sorry if I spelled that wrong). The servo horn I am using now is by KoPropo. The one with the silver ring around it.
JoeyE is offline   Reply With Quote
Old 12-30-2005, 06:58 AM   #4
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
yes. use them. whether directly integrated into the horn, or into the steering assembly. the idea is that they have to be strong enough for the application, and drift will not be an issue. i use the kimbrough heavy duty one. i even cut my chassis to fit it, as it like it so much. it's way strong and never leaves center outside of crashing, which i don't do. my car is never out of trim, ever. and yes, i smash things quite often.
the jrxs guys at our track leave with headaches all the time, because their trims are off from not running a servo saver. they can't fit one. by all means, if you can run one, then do. if the saver in your kit sucks, find a better one. or scrap the belcrank saver, and just go direct on the spline.
the idea of a saver is to purposely put a weak link in the system. one that is 100% elastic. without it you will be exposing the next weakest link. whether it's a gear, a ball stud, or a horn, it usually fails permanently.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
WTB XX4 outdrive savers Autocrosser R/C Items: Wanted to Buy 3 03-27-2008 09:33 PM
NIP, Kimbrough gears and servo savers Kraig R/C Items: For Sale/Trade 3 08-12-2007 07:31 PM
Servo Savers RCSteve93 Electric On-Road 2 12-23-2006 07:04 PM
Servo Savers thommo09 Australian Racing 3 07-30-2006 08:11 PM
SEO by vBSEO 3.5.0
