Easy, Quick important question from a noobie. About connecting wires.
Hey. My ESC has 2 wires, then it has 2 coming out of motor. The pic below will help u understand. Well my yellow connecter is stuck inside the yellow connector on the ESC's end...I cannot get it out, so I was wondering if I could so something like this:
http://img502.imageshack.us/my.php?image=s7gw.jpg
Thank You.
Cut the wires (cut off connectors)
Strip the wires
Solder
Wrap
Thank You.
Strip the wires
Solder
Wrap
Just solder away the connectors from the motor and directly solder the wires from the esc to the motor.Remember, yellow to positive and blue to negative.
Ohh...good thinking.
As you can see, plenty of room to connect:
(i just threw the reciver in there, im not keeping it all sloppy like that).
just solder the speedo wire straight to the motor and unsolder the motor wires
