Like Tree27Likes
Old 11-01-2016, 02:23 PM   #46
Default PRO-10
Hey guys bring these pro 10's out to 360 on wed and sundays, I have a Speedmerchant RoadKill 10, I love this class!!! bigger faster easier to see and drive!!
Bring em out boys
madmikepags is offline   Reply With Quote
Old 11-27-2016, 01:11 PM   #47
pullstarter's Avatar
Trader Rating: 14 (100%+)
Has anyone managed to use a servo saver rather than the stock solid servo arm that comes with the kit?
pullstarter is offline   Reply With Quote
Old 11-27-2016, 01:51 PM   #48
hanulec's Avatar
Trader Rating: 27 (100%+)
dont see why this won't work
i did it w/ the P10
what components are you using? got any pics?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-27-2016, 03:05 PM   #49
pphaneuf's Avatar
I've been having a bit of trouble fitting CRC rear tires on the P10W, a bit like some problem people had with early P10, as I recall, any tips?
pphaneuf is offline   Reply With Quote
Old 11-27-2016, 03:59 PM   #50
i did it w/ the P10
Howdy, I haven't got the kit yet, expecting it this week. I have Kimbrough savers and also Tamiya savers (the 3 spring type) which I can use an alum arm on (as pictured below). Just wasn't sure how i'd go with clearance/arm length?
http://www.rcmart.com/3racing-3racht...cPath=1099_808
Old 01-12-2017, 05:16 AM   #51
san.'s Avatar
Trader Rating: 60 (100%+)
Anyone know where I can find a rear axle for the P10W? Or one that's compatible.
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 01-12-2017, 05:42 AM   #52
foampervert's Avatar
Send a message via MSN to foampervert
Default Servo Saver
I'm using a TOP racing servo saver (which is like a kimbrough). I found that I needed to mount the servo much further back (even when the ball stud is facing backwards). To this end, I built the servo mounts facing backwards and attach the servo to the front (top) of the servo case mounting tabs, instead of the bottom of the tabs (as stated in the manual).
This does push the weight slightly backwards, but I'm not so concerned about it.
Roche Rapide P10W 1/10 235mm Competition Pan Car Kit-img_0550.jpg   Roche Rapide P10W 1/10 235mm Competition Pan Car Kit-img_0549.jpg
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 03-17-2017, 05:04 PM   #53
LOW ET's Avatar
Trader Rating: 96 (100%+)
picked up a roche 235mm, any ideas for center/side shock fluids, center/side shock springs, front springs? this will be for mod on asphalt. thanks for any info.
Taz_S likes this.
LOW ET is offline   Reply With Quote
Old 04-15-2017, 08:43 PM   #54
Trader Rating: 28 (100%+)
Any idea when these will be back in stock?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-15-2017, 09:41 PM   #55
hanulec's Avatar
End of April/beginning of may
pphaneuf likes this.
Old 04-16-2017, 12:18 AM   #56
Pro10noob's Avatar
Centre 400/450 from Tamiya with yellow Tamiya spring, side,200/250+ Tamiya with Associated blue spring and if you have room enough, use the CRC green side spring on the kingpin or. 20 or.22 spring.
Regards Roy
LOW ET likes this.
Pro10noob is offline   Reply With Quote
Old 06-05-2017, 07:29 PM   #57
gijoe64's Avatar
Trader Rating: 30 (100%+)
Any update when kits will be back instock?
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is online now   Reply With Quote
Old 07-18-2017, 03:05 AM   #58
I started building mine today, and it looks like there has been a running change - mine has what look to be Destiny VD12 side links and rear pivot. Thankfully there was an additional sheet in the manual to show the changes
Taz_S and pphaneuf like this.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is online now   Reply With Quote
Old 07-18-2017, 03:43 AM   #59
pphaneuf's Avatar
Oh? Got some pictures of the changed parts, on the car?
XRay X10'16, Roche Rapide P10W, Roche Rapide P12-2017, Carisma GT24R
Old 07-18-2017, 04:41 AM   #60
Yep, attached
Roche Rapide P10W 1/10 235mm Competition Pan Car Kit-imag0424.jpg   Roche Rapide P10W 1/10 235mm Competition Pan Car Kit-imag0425.jpg   Roche Rapide P10W 1/10 235mm Competition Pan Car Kit-imag0427.jpg
Taz_S, THEBIGBULL and pphaneuf like this.
Scott Tapsall
