Like Tree10Likes
Old 07-13-2016, 12:58 PM   #1
Default Team CRC Gen X 10 R/T
http://www.teamcrc.com/crc/modules.p...rticle&sid=216
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 07-13-2016, 01:00 PM   #2
Let's use this thread to discuss the Gen X 10 R/T specifically and keep the World GT-R thread to more general topics....
Also, feel free to post pics of your cars!
Old 07-13-2016, 02:41 PM   #3
dumper - what center spring are you using on your car?
Micro_Racer is offline   Reply With Quote
Old 07-13-2016, 04:14 PM   #4
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
subscribing, I have a Gen X SE but I'm watching this for tips.
offroad - AE B44.3 / /Serpent SRX2 MM / /
onroad - XRAY 2017 T4//CRC Gen X SE- 17.5 GT//Xray X12-17' GT12
support your local tracks- Beachline Raceway-Revolution RC-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 07-13-2016, 04:19 PM   #5
JEFFs SC10's Avatar
is there a manual I can download for this?
Old 07-14-2016, 06:49 AM   #6
Red or white depending on what the car is doing. If I need more steering, I run red, if I need less, then white.
Old 07-14-2016, 06:51 AM   #7
The manual is not online yet, but it does come free inside every new kit!
Old 07-14-2016, 10:55 AM   #8
JEFFs SC10's Avatar
Lol I just got a Gen X SE to run this class but plan to get this after I get a little better at driving.
Old 07-14-2016, 11:28 AM   #9
Jsaves's Avatar
Default Conversion kit
Brian,
Will there be a conversion kit to turn a LE or SE into the new 10 R/T?
Thanks and God Bless
B
Jsaves is offline   Reply With Quote
Old 07-15-2016, 04:43 AM   #10
Just finished building this kit. The first major for me will be the Summer Slam @ the Gate in two weeks. I really like the front end width adjustment. No more removing the arms just to change the front track.
I am also using the new McAllister C6 body. First body designed for the class.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 07-15-2016, 07:31 PM   #11
Gravity Dodger's Avatar
Question for those who have built the kit, I used the 5mm spacer for the front A arm as recommended in the instructions and my front ride height is still 7mm did you guys use shims to bring it down to 5mm? I've gone through the instructions several times to see if I assembled something wrong but everything looks right.
Team CRC Gen X 10 R/T-1468636392004-1229173363.jpg
Team Destiny, Power by TSR
Gravity Dodger is offline   Reply With Quote
Old 07-16-2016, 03:57 AM   #12
I have run WGT-R for almost a year and I think that the spring shim is the issue. To get them to handle well they need droop in the front and removing that shim will drop the nose and add that droop. Just part of the setup.
NORCAR @ The Gate
Old 07-17-2016, 04:27 AM   #13
First race with the new car yesterday. The Gate has the new carpet and the layout has fast sweepers on and off and tight/technical turns for the infield. First off the car as I set it up had a ton of low speed steering and a little low on on power (I had maximum caster as my starting point). I moved two shims to the front to reduce the caster and now the steering was more balanced. I did start with .45mm front springs instead of the kit .50. Other changes were to go to 50k lube in the side dampers and all the way to a black center spring. I am really happy with the car and before the next race I will put stiffer rear side springs on because as grip came up body roll became dramatic. I think that will make the car even better on the sweepers. When it was over I TQ'd and won in a light field.
NORCAR @ The Gate
Old 07-17-2016, 02:43 PM   #14
Thanks OD, I switched to the .45 front springs and am running some droop and now I'm at the 5mm ride height. I'm preparing three bodies for this car to start; McAllister wgtr Vette, HPI Carrera GT, and the HPI Viper, can't wait for our next club race on Wednesday to try the car out!
Old 07-17-2016, 04:15 PM   #15
JEFFs SC10's Avatar
What caster blocks do you guys run up front?
Are you guys gluiing the sidewalls of your front tires?
