Like Tree18Likes
Old 02-07-2017, 06:30 AM   #106
The setup I ran in Snowbirds is the same setup I have run pretty much everywhere:
- .45 1/10th front springs, kingpin almost touching the rim
- Mid track width in front
- 3/4 degree of camber
- 10 degree blocks (adjust shims as needed. Start all back, if car diffs out, start putting them forward one at a time until it stops)
- White center spring, stock shock oil
-.45 side springs, just touching, tweak from there
- 7k in the tubes
-very little rear droop. just enough to tell the pod is drooping
-200mm rear track width
-Battery in line to the front
-Speed control mounted behind battery, receiver in front of the battery
-Protoform GT body (when using this body, I use the #1757 carbon bumper as it is a little longer and helps "fill up" the long nose of this body
- I use the GFRP body post set (available through CRC) in the rear with this body. I use it on all four corners with other bodies
- I only glue my front tires half way up. Doing this has no impact on handling but will allow some rubbing of the track barriers.
-7/8 front tire traction (don't be afraid to reduce this if it is too much for you.)
If anyone has any questions, feel free to ask
Brian Wynn
Team CRC
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 02-07-2017, 06:32 AM   #107
Originally Posted by thefnshow View Post
need some help guys...just picked up an original gen x 10 car and it didn't have the proper shock it.started to email crc and then they fell off the face of the earth...does anybody happen to know the part numbers for the shock and spacer ball that goes in the shouck for the aluminum/graphite shock mount ? thanks
Feel free to email me directly brian at teamcrc.com
Or call CRC 315-338-0867 and I will help you out.
Brian Wynn
Team CRC
Old 02-07-2017, 06:35 AM   #108
Originally Posted by liljohn1064 View Post
Anyone have a setup to post other than box stock?
John, feel free to call me here at CRC. Or email me. Actually that goes for anyone on here, regardless of car brand. I have worked on just about all of them.
Old 02-07-2017, 07:20 AM   #109
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Brian Wynn
Team CRC
Great!!
Bruce and I have a few questions
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 02-07-2017, 07:39 AM   #110
Still Bill's Avatar
Brian Wynn
Team CRC
Hi Brian,
Congratulations for your win at the Snowbirds. You had me glued to the LiveRC coverage rooting you on.
How about a setup for the old CRC gray carpet? Only changes I have been using (since IIC) from what you have above are .50 front/side springs and a red center spring with more rear pod droop.
Do have a Team Scream motor on order...and patiently waiting for it. LOL
Many thanks.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-07-2017, 09:13 AM   #111
I would run the same setup. The only change I would possibly make is running the battery transverse.
Old 02-07-2017, 12:26 PM   #112
Still Bill's Avatar
Yup. Already tried transverse on my second WGT-R car. Didn't work as well as in-line on gray carpet; so, am saving that one to try on asphalt (in spring).
Thanks Brian.
Bill
Old 02-13-2017, 11:04 AM   #113
Trader Rating: 24 (100%+)
i know this isn't the right thread but i need all the help i can get...i have an original gen x 10 and i was wondering if anyboy has part# 3337..the 7/8 standoff for the losi shock..if you have one that you'd be willing to part with then please pm me...thanks
thefnshow is offline   Reply With Quote
Old 02-16-2017, 02:03 PM   #114
I just picked up a new kit. Excited to start putting it together and get it out. First car I've ever raced that wasn't offroad. Awesome looking car so far
brian8301 is offline   Reply With Quote
Old 02-17-2017, 05:55 AM   #115
Trader Rating: 114 (100%+)
Welcome.
Setup is much more important and sensitive in on-road than off-road. Make sure you have everything balanced and setup correctly before running it.
I guarantee you it will be a much more fun and better experience!
Chris Furman is offline   Reply With Quote
Old 02-17-2017, 07:32 AM   #116
Originally Posted by Chris Furman View Post
Welcome.
From what I've read in this thread on the previous pages, I'm going to build straight from the book to start. Looks like I'll just need some ballast to balance the car to offset my electronics? Is there any "balance station" or setup type plates you guys use while doing this or just some common sense and see how the car acts n the track?
Old 02-17-2017, 07:39 AM   #117
Just try your best to put your electronics in line, keep the weight balanced.
Check earlier posts a page or two back on how to adjust tweak without any tools. It's the easiest and best method IMO. You just life the front, check the tire and adjust accordingly.
Old 02-17-2017, 07:47 AM   #118
Still Bill's Avatar
There are two small centered holes at the front and rear of the chassis that are for use with "balance buttons" to check the side-to-side weights. I need to check where I got those buttons. Have been using them to initially setup my on-road cars for over 10 years.
Edit: Ah ha! They are called IRS Balance Buttons #3020 which are still available from Muddslide Motorsports for $11.70. Note: These are far superior to the ones offered by Hudy...for more money.
Hopefully this answers your question. Enjoy the car.
Bill
Old 02-17-2017, 07:59 AM   #119
liljohn1064's Avatar
Trader Rating: 17 (100%+)
You've already helped me indirectly Brian. Chris from our club picked your brain at the birds and brought your setup ideas for our track back with him and they worked perfectly. I posted what I have the WGT-R thread and the car is very driveable now. I just need to get more practice at certain aspects of braking and carrying more corner speed. I tend to drive too safely. I always finish, but hardly ever first.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-17-2017, 10:37 AM   #120
I'm assuming the electronics section of the forum will be a bit wide on suggestions so I'll put it here.
What size, type wires are you running on 1S esc and 17.5 1S motor for this chassis?
I'm asking because the HW ESC OEM wires look a bit small in diameter and could possibly be an amperage restriction?
CRC Gen X 10 R/T
Hobby Wing V3.1 ESC
Trinity Monster 17.5 1S
1S lipo
New to on road...
gmackhurry is offline   Reply With Quote
