Like Tree18Likes
Old 10-19-2016, 09:18 AM   #76
That is exactly what I did too for mounting the Caddy
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-19-2016, 08:00 PM   #77
Dumper :On your caster shims -where are you placing them on the 5 degree blocks.Are you using the kit springs front and rear and in the center shock?Most importantly where are you running the battery.Also the width narrow-middle or wide and long or short wheel base?
Just started trying the tranverse battery and Narrow with the short wheelbase .
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 10-20-2016, 12:53 PM   #78
celt's Avatar
Originally Posted by dumper View Post
Gen X 10 R/T Wins the IIC in Vegas!
http://www.teamcrc.com/crc/modules.p...rticle&sid=219
But...but...it's pink!
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
Old 10-24-2016, 01:09 PM   #79
al dente's Avatar
pink is worth .1 a lap. proven fact.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 19-22, 2018
al dente is offline   Reply With Quote
Old 10-24-2016, 03:13 PM   #80
Gravity Dodger's Avatar
All of those speed tips you gave me at iic and I have to learn about this one on the internet? Thanks for the help the new R/T car is amazing, our track had a three day event called Bone Crusher and it was the fast car all weekend.
Paul
Team CRC Gen X 10 R/T-20161023_185817.jpg   Team CRC Gen X 10 R/T-fb_img_1477330983361.jpg
Team Destiny, Power by TSR
Gravity Dodger is offline   Reply With Quote
Old 10-24-2016, 04:45 PM   #81
Jsaves's Avatar
Default New GT-R fast
Hey took my new GTR out this weekend for our first club race and it was fast. We had two heats of GTR cars and the driver held the car up, but in the A main I got my head in it to finish a hard charging 2nd place. I raced it almost totally box stock except for getting to 5mm in front. I will try my set up from the SE next race for what I think will be even more speed.
Thanks CRC!
Jsaves is offline   Reply With Quote
Old 10-24-2016, 06:00 PM   #82
Still Bill's Avatar
Paul
Paul is da man!
Still Bill is offline   Reply With Quote
Old 10-25-2016, 03:23 AM   #83
celt's Avatar
Default Pink is fast...no doubt!
And I can see it.
We run on old CRC grey carpet, that as I understand, has much less grip than the newer black stuff most run on. In addition, we have an off-road program that run foam tires on buggies that seems to pick up our groove. So essentially, we are starting our race day with a completely "green" track.
Would you recommend moving the battery traverse for more rear weight bias? Just not sure moving the battery in-line a few millimeters back is going to be enough. Chassis is awesome, just need a pinch more traction for our low bite surface. I see no chance of traction rolling here...
Stan Garvin
Old 10-25-2016, 06:16 AM   #84
Originally Posted by celt View Post
And I can see it.
I have raced on some low bite tracks using the same setup. The main thing I change is tire prep. Try this: After you marshall, go back to your pits and take the body off. Fully dope all four tires and wipe them off. Now assuming that you usually dope your tires at the same time leading up to when you run, about ten minutes before then, do a normal tire dope. Then at your normal time, do it again. Cleaning the tires then doing a double dope will really bring up the grip of the tires.
I have thought about going transverse for low bite situations, but that would require moving the electronics around. So it is not an easy thing to just try. If you do take the time to do it, I would be interested in hearing what you find out.
Brian
Old 10-26-2016, 04:36 AM   #85
celt's Avatar
Brian
Thanks for responding Brian...
I'll try that for sure. Wouldn't hurt to have a second chassis for this sort of thing. I'll report back.
Stan Garvin
Old 10-26-2016, 06:31 AM   #86
big_ads's Avatar
Trader Rating: 79 (100%+)
Send a message via MSN to big_ads
Brian
Last season I was using an LE for my GT-R car and experienced similar low bite conditions. I did take the time to move electronics around and put the battery transverse. It was night and day difference, at least in my experience. Consistently worth a half second per lap. Like Brian said though it is a pain if you want to go from transverse to in-line all the time and there were some definite performance advantages to being in-line when the bite came up.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Protoform/Pro-line - Big Head Racing - Dumpers Speed Shop
big_ads is offline   Reply With Quote
Old 10-26-2016, 11:02 AM   #87
celt's Avatar
Thanks guys, I'm convinced I need to do that...I purchased a second R/T for parts, I'll build that one up traverse...
Stan Garvin
Old 10-27-2016, 05:37 AM   #88
I ran transverse at the Halloween Classic against Brian. This weekend with the same layout down, I will be trying his inline setup.
Great to have a car as flexible as this one to try these things.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 01-31-2017, 09:59 AM   #89
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Anyone have a setup to post other than box stock?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-31-2017, 03:50 PM   #90
Still Bill's Avatar
Wink
Box stock is really good as a starting point for just about any carpet track. Changes are dependent on the current condition of the track being run. Usually just messing with front/side/center springs and pod droop.
Traction has been pretty good at the 209 Raceway in Stockton, CA this season; so, I only run the in-line configuration there. Saving my transverse setup car for the asphalt tracks in the Spring.
Still waiting for a new Team Scream 17.5 motor (spec'ed for WGT-R). <grin>
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
