Like Tree18Likes
Old 08-08-2016, 06:41 PM   #46
NutDriver's Avatar
Trader Rating: 15 (100%+)
I think he means the 190mm Caddy that's been around for a while now.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 08-08-2016, 06:55 PM   #47
YoDog's Avatar
Trader Rating: 26 (100%+)
That's what I thought... It still looks good though!
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 08-15-2016, 10:19 PM   #48
Still Bill's Avatar
Are 190mm bodies legal???
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 08-16-2016, 04:47 AM   #49
Any body on the list (and some are 190's) as long as the tires don't stick out. The MX-Stang from McAllister is a 190 and it fits the CRC when it is in the narrow configuration very well. It works well like that too!
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 08-16-2016, 06:39 AM   #50
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
The 200mm Caddy just came out.
I put the Porsche GT1 body on my car and it looks sick on the track!
Does anyone have problems with the kingpin rubbing on the wheel?
It was suggested for me tonrun a 12 scale kingpin.
JEFFs SC10 is offline   Reply With Quote
Old 08-16-2016, 08:00 AM   #51
Still Bill's Avatar
Default Kingpins rubbing...
It was suggested for me to run a 12 scale kingpin.
Thinking that the 1/12th kingpin worked great for WGT carpet; but, not for WGT-R/T where you need more suspension travel with rubber tires. Could be wrong; but, that is my logic.
Are you using the new style (fixed 1/8" axle) or old style (adjustable 5/16" leading/trailing axle) steering blocks? The R/T kit comes with the new ones. I have one car with each style of steering block for testing purposes.
With the new style #3221 steering blocks that came in the R/T kit build it per the manual. One of my cars is this way.
With the old style #3251 adjustable steering blocks, place the axles in the leading position to achieve more clearance at the kingpins. Then, run the short wheelbase configuration to not make the wheelbase too long overall. My other car is this way.
Bill
Old 08-16-2016, 09:14 AM   #52
If your kingpin is rubbing on the wheel, then you have the length of the kingpin too long. You will need to screw the kingpin in until it stops rubbing. Our kingpins are adjustable in length and there is not a need to run so much front droop that it hits the wheel. it should be close, but not touch. 12th scale kingpins are not that good in GTR.
Brian Wynn
Team CRC
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 08-16-2016, 06:59 PM   #53
JEFFs SC10's Avatar
Thanks Brian,
I'll try adjusting, I'm all about the easy fix.
Still working on setup issues, I was traction rolling like crazy this past weekend.
Looks like 0.5 deg camber in the front is all I need, my car has A LOT of front grip.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
Old 08-16-2016, 10:16 PM   #54
Still Bill's Avatar
Default ESCs
Any cost effective 1S ESC options out there for WGT-R/T besides ORCA and Hobbywing?
Would need to have 6V output for a KO RSX-12 steering servo.
Thanks.
Old 08-16-2016, 10:21 PM   #55
racer x 1's Avatar
Trader Rating: 27 (100%+)
Thanks.
I've heard great things about the SMC 1s esc. Still running. First generation hobbywing 1s without any issues
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 08-16-2016, 11:35 PM   #56
Still Bill's Avatar
Default ESC
Matt,
Many thanks for the information about the SMC 1S ESC. I verified that it was approved by ROAR; and, ordered one with a programming box for $99.95 plus $8 shipping (3-day).
Wow! That was easy. Oops! Forgot to look at 17.5 motors...LOL
Stay tuned.
Bill
Old 08-17-2016, 04:34 AM   #57
Thanks.
This one works well. The problem is getting a programmer. Less than $50.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
NORCAR @ The Gate
Old 08-17-2016, 06:04 AM   #58
I run a Hobbywing Justock XR-10 and a booster. Easy and cheap.
Old 08-17-2016, 09:23 AM   #59
YoDog's Avatar
I have 2 of these and they work great!
The deal with the programming box is getting it when they are in stock. Check both the International and U.S. warehouses.
Old 08-19-2016, 01:21 PM   #60
Default What Body Fits ?
Well it looks like the new Protoform Caddy body does not fit without serious bumper modification and body post relocation. What body's fit without hacking up my chassis ? What is that body Mr. Dumper is using ? Looks like it fits well !
John
jfle98 is offline   Reply With Quote
