Like Tree18Likes
Old 05-28-2017, 06:46 PM   #181
Still Bill's Avatar
Originally Posted by RMKinWI View Post
or What range of 64p pinions one should have to run this car?
What tooth 64p spur came in your kit?
For what 17.5 motor?
And for how large a track!
Still Bill is offline   Reply With Quote
Old 05-28-2017, 08:26 PM   #182
RMKinWI's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Still Bill View Post
What tooth 64T spur came in your kit?
I Received a 96t Spur. If I have to buy pinions I can surely buy different spurs if needed. I will be running a Reedy Sonic 540-M3 Short Stack 1S Spec Brushless Motor (17.5T) #ASC269 and the track is Medium size the current GTR's are running 12.5 to 13.5 Second laps.
https://www.youtube.com/watch?time_c...&v=8YT6boFJOrM
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 05-29-2017, 04:50 AM   #183
With a new Team Scream I run 38/92 (Fenix gear diff). Medium size indoor carpet (90 x 40). Timing at 42.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 05-29-2017, 11:20 AM   #184
Still Bill's Avatar
So, old_dude's gearing would work out to be about a 40.5T pinion with a 96T spur.
I am running 40-42T pinions with a 96T spur for all my carpet racing using a Team Scream The One 17.5. Depending on the pinion used, the rollout is approximately 81-85 with the CRC WGT-R tire (62mm diameter).
Did put a Yeah Racing 30x30mm fan (#YA-0180) on one car with their adjustable Heat Sink Fan Mount (#YA-0328GM). Have it nicely parked above the TS motor in the pod. Really good fit.
Bill
Old 05-30-2017, 07:18 AM   #185
Trader Rating: 76 (100%+)
I am running 40-42T pinions with a 96 spur for all my carpet racing using a Team Scream The One 17.5.
Bill
Good to know Bill! I ran my WGT-R this weekend and my Motive M2 temps were in the 140 range so I'll be looking into a fan as well. My question is why are the temps so high? Is it due to more rotating mass from the rubber tires compared to the foams? Also, are you guys hardwiring the fan directly to the battery posts?
My car did feel pretty good for it's first outing. I ran 10.9's consistently by the end of the day on an 80 x 40 black carpet track with a subfloor. I believe the real fast guys were in the 10.3 - 10.4 range at the last big race so I'll be making some minor setup changes and playing with different things this summer.
MUDVAYNE is offline   Reply With Quote
Old 05-30-2017, 07:57 AM   #186
liljohn1064's Avatar
Trader Rating: 17 (100%+)
72
(96/.64) * .48 = 72
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 06-01-2017, 01:48 PM   #187
Originally Posted by dumper View Post
The setup I ran in Snowbirds is the same setup I have run pretty much everywhere:
- .45 1/10th front springs, kingpin almost touching the rim
- Mid track width in front
- 3/4 degree of camber
- 10 degree blocks (adjust shims as needed. Start all back, if car diffs out, start putting them forward one at a time until it stops)
- White center spring, stock shock oil
-.45 side springs, just touching, tweak from there
- 7k in the tubes
-very little rear droop. just enough to tell the pod is drooping
-200mm rear track width
-Battery in line to the front
-Speed control mounted behind battery, receiver in front of the battery
-Protoform GT body (when using this body, I use the #1757 carbon bumper as it is a little longer and helps "fill up" the long nose of this body
- I use the GFRP body post set (available through CRC) in the rear with this body. I use it on all four corners with other bodies
- I only glue my front tires half way up. Doing this has no impact on handling but will allow some rubbing of the track barriers.
-7/8 front tire traction (don't be afraid to reduce this if it is too much for you.)
If anyone has any questions, feel free to ask
Brian Wynn
Team CRC
Dumper, what tweak springs and front springs come in kit? I'm trying to figure out how close I am to this setup. Thanks!
Old 06-01-2017, 03:21 PM   #188
big_ads's Avatar
Trader Rating: 77 (100%+)
Send a message via MSN to big_ads
CRC kits come with .50 springs all around.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Protoform/Pro-line - Team Genesis R/C Products - Big Head Racing - Team PRCP
big_ads is offline   Reply With Quote
Old 06-05-2017, 05:10 AM   #189
celt's Avatar
Default quick poll...
Most running the short wheelbase? Thoughts or comparisons on either?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 06-06-2017, 05:02 AM   #190
My RT and F1 both came with .45's.
NORCAR @ The Gate
Old 06-06-2017, 09:05 AM   #191
All CRC car kits come with .50 front and side springs, as well as a red center.
Old Dude may need to zero out his calipers......
liljohn1064 likes this.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 06-06-2017, 09:54 AM   #192
Still Bill's Avatar
Default Yeah fan and bracket
Some pics of the Yeah Racing fan setup on one of my WGT-R/T cars...
Team CRC Gen X 10 R/T-yeah-fan-1.jpg   Team CRC Gen X 10 R/T-yeah-fan-2.jpg
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Old 06-06-2017, 01:15 PM   #193
celt's Avatar
Awesome Bill!
Hey, what do you think of those body posts? Just ordered my first set, have them tomorrow.
Stan Garvin
Old 06-06-2017, 02:01 PM   #194
Originally Posted by celt View Post
Awesome Bill!
You can look at mine tonight.
Old 06-06-2017, 06:05 PM   #195
Still Bill's Avatar
Awesome Bill!
I run the aluminum/composite body posts at all four locations on both of my WGT-R/T cars. And, even though they are a tad heavier, I can still make minimum weight.
I believe that Dumper still only runs two at the rear of his car.
Bill
