Like Tree18Likes
Old 04-07-2017, 06:10 AM   #151
Default Say Dumper.....
Have you ever thought about make some WGTR rims with a 12mm hex so we could run these tires on other chassis's? IMHO these tires look better on the VTA cars than the HPI tires and there is no problem getting them. Just wondering.
Rich
FunStuff is offline   Reply With Quote
Old 04-07-2017, 06:30 AM   #152
We haven't. If we did do it, it would change the entire scope of the VTA game. You would have to have these tires, and that is not what VTA is about. I know the VTA tires are hard to get right now, but it sounds like Rob King is on it and there is a fix coming. So there was no need for us to get involved with these tires.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 04-07-2017, 06:42 AM   #153
Understood. Tks for the quick reply.
Rich
Old 04-23-2017, 09:00 AM   #154
celt's Avatar
Default Pod droop
Just curious what others are running for rear pod droop.
Sitting at 2.00mm
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-23-2017, 01:16 PM   #155
Still Bill's Avatar
Sitting at 2.00mm
Check back to Post 106 from Dumper on this thread. Since then I have been running minimal droop too (maybe
1mm); except, on bumpy surfaces where I run about 2mm.
Bill
Still Bill is offline   Reply With Quote
Old 04-23-2017, 03:29 PM   #156
celt's Avatar
Bill
Thanks Bill...
Putting a +/- 1mm spacer under the center shock piston?
I could see if I can thread the ballcup on a pinch more I suppose.
Stan Garvin
Old 04-23-2017, 05:39 PM   #157
Still Bill's Avatar
Thanks Bill...
I did just thread the ballcup onto the shaft further. Used the o-ring under the piston method on my regular WGT cars though.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Old 05-09-2017, 05:54 AM   #158
Trader Rating: 76 (100%+)
Subscribed
Still Bill likes this.
MUDVAYNE is offline   Reply With Quote
Old 05-09-2017, 06:23 AM   #159
Still Bill's Avatar
Originally Posted by MUDVAYNE View Post
Subscribed
Now...Go to Dumper's Post 106 on this thread.
Old 05-16-2017, 11:56 AM   #160
Still Bill's Avatar
If you check the latest picture of Dumper's WGT-R/T on the Team CRC website, you will note that he is now using two motor plates on his rear pod with a motor fan attached to the one on the left side. Kewl!
Old 05-16-2017, 07:30 PM   #161
I believe it is a lexan mount he made and it is attached to the pod .
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 05-16-2017, 07:55 PM   #162
TOM MAR's Avatar
I could not find it, got a link?
TOM MAR is offline   Reply With Quote
Old 05-16-2017, 08:08 PM   #163
Still Bill's Avatar
Nope. Called Dumper yesterday and he confirmed it. But, he is thinking about relocating the fan closer to the motor for more effect.
And.....................He is also back to using the PFM-10 body after having an issue with the Ford GT.
Old 05-17-2017, 04:34 AM   #164
There is room to drill and tap a 4-40 hole in the lower right of the left pod. I have had my fan there from the original build of the car. Helps balance the pod too. Not a totally effective fan location but it serves two purposes.
He has run the PFM-10 for quite awhile. He ran the GT at the Indoor Champs and the Birds. He was running the PFM at our track (90 x 40) and AustinTown (similar size). My thoughts are big track GT, small tracks PFM.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 05-17-2017, 08:18 AM   #165
Ok, stupid question here. Why is there a need for the fan in 1S racing? My motor temps in my 12th scale are around 130 and that's on an 80 x 40 black carpet track with a subfloor. The only thing I could think of is that the car is bigger and weighs more with the rubber tires. Or am I totally wrong on this assumption?
