Tamiya TZ vs RZ
Hey guys just want to see what you prefer TZ or RZ please give a reason as to why you chose what you chose.
Cheers, Pat |
Cheers, Pat the RZ is also good and fast for Long race tracks i mean high speed racetracks. but if you will be racing in technical circuit the RZ is no match for TZ but if you'll be matching the TZ to RZ in a long track RZ can keep up.. but then after a few runs maybe 10 runs you'll begin to notice a slightly slowing performance for these motors.. so u have to cut the comms... so for me i prefer getting the TZ tnx i hope these helps... |
RZ = RPM based motor
TZ = Torque based motor Use whatever suits your particular track layout. |
I have both motors. I prefer TZ because it has way more torque than RZ. BTW, I cut the comm on both motor and replace the brushes and broke in the motor and I put the motors on CTX-M and TZ has more RPM and pulls more amps!
