Glitching Woes... (any help appreciated... :) )
#16
oh and ive been using the xs3... but i use the same radio in another car w/ no problems...
usually i use the m8... but since i got surgery last week, ive been driving one-handed... its easy w/ the xs3, but the m8 is near impossible because the wheel is so far from the trigger that my thumb can barely reach...
#17
Have you tried the spektrum in your M8?
#19
have you try, open both RECEIVER and ESC casing,
some accumulation little small rock or sand may create short circuit that cause glitching
#20
no spektrum...
as far as the receiver and esc, I have tried two different ESCs and two receivers... the second receiver seemed a little better...
I just went out to try it again with thicker servo tape on the receiver and didnt get 10ft before i broke... not due to glitching though... user error (try driving with one hand and see how well you do...)
we'll see tomorrow...
#21
Had a had major glitching with my xr3.. I replecd the servo and it was better but not good..
I fixed it by buying a Hitec DCX dual conversion reciever(40 bucks) and crystals (10.00).. i used the radio for 7 years without a single glitch after that.. i finnally retired it because of its age , and as far as i know the guy who bought it is till using it glitch free..
you only need a new xstal for the reciever.. buy a single the same freq as your radio..I know alot of people dont lie hitec, but i love there radios..
i currently use a Lynx 3d with the dcx without issues..
#23
Originally Posted by jbrow1
Are you running a plastic or graphite chassis? If graphite don't let your antenna wire touch it. Some people drill a small hole in their antenna tube above where it mounts in the chassis, and run it thru there so they can completely keep it off the chassis.
Is your motor nice and clean, and does it have capacitors on it? If no on the capacitors then you'll need to get some.
Make sure all crystals are pushed fully in. That's about it for my suggestions besides making sure your radio batts are fully charged.
(the graphite chassis below)
#24
Originally Posted by killer89
i changed the reciever to airtronics and the crystal to a new set...
WAY better than the first time,but still glitches every once in a while... this is at my house, and i know that at my track it was worse the 1st time...
Send photo of your buggy so we can examine better.
Your equipment look fine to me : LRP V7.1, XS3.
Have you reset LRP V7.1 to match your RX ( I mean press SET button ) ?
Would you like to try other channel ?
#25
i will get a pic tomorrow... i think the problem might be going away, but i broke an arm today and haven't gotten to run since...
ill replace the arm and run it tomorrow...
On another note, when i broke the arm and drove the car with 3 wheels out in the street (just wanted to see if it would run on 3 wheels) it was glitching like CRAZY from the broken arm dragging in the front... what causes this?
yes the esc is set to the car. yes i have tried other channels (68 at first, then later 90)... I run my other losi buggy (bk2) on channel 68 with NO problems...
#26
friction can cause glitching, check bearings, maybe one is very bad and the metal scrubs.
Or try putting a power cap on the receiver, works good.
#27
....or you can make all these glitching issues ancient history --> buy a Spektrum
#28
imr : metal friction ? ball bearings ? .... ohh please..... you read too much rc car action's tips and trick . Nitro cars will be glitching like hell if metal friction really cause glithching.
#29
edit : on second thought, have you check all connectors ? are they fit tightly or loosely ? Cable split ?
#30
Sorry I tried to help, will never do it again, the thread starter said (any help appreciated).
So why not suggest the (maybe) impossible if nothing from the above worked for him?
The only thing he didn't change is his car, maybe that will help.
