dosnt anyone now
#16
R/C Tech Elite Member
if you look at the link, they make a 40mhz receiver too? If i were you, i would get a different radio, that 40mhz is going to give you a world of trouble down the road when racing more classes and having to find 40 mhz receivers, 75mhz is what is used today and 27mhz as well!
#17
i am not going to race international because i am only 15 but in denmark i cant use 75 ore 27 fm its ilegal but many thanks for the answers do you now any other receivers synthesizer and 40 mhz because i think it is vere expensive
#19
it is ilegal i think for 27 mhz fm but legal if its am im not sure but i am sure that it is ilegal to drive with 75 mhz in denmark but i would like a cheaper receiver
#20
sorry i can see that it only cost 69 dollars so if you could give me a link to a place that i can buy it in 40 mhz that would be nice
#23
#24
Many things are said in this topic. There are some things to keep in mind: Any transmitter/receiver combo you buy will work as long as they are on the same freq.band (in your case 40mhz FM) A 40MHZ FM transmitter and 40mhz AM receiver will not work! All receivers made 1990 have a BEC system on board, so don't worry about that. I run myself a Sanwa M8 transmitter (40FM) with a Futaba receiver (40FM) in my Yokomo LCG. In my 1/18 XRAY M18 I run the same transmitter but with Jeti receiver (40FM) and last but not least: in my 1/8scale hydroplane raceboat I run again the same transmitter but with a Multiplex Pico receiver (again 40FM). So you see you can run any transmitter/receiver combo as long as they are on the same freq band. Hope this will help you.
#25
