Old 06-30-2007, 09:49 PM   #1171
anthony390's Avatar
Send a message via AIM to anthony390
Originally Posted by rccartips View Post
Hi Anthony,
Body is from a JADA toy rc car... with a lot of cutting, sanding, epoxy work to look like an Initial D car... it does not come with the M04 chassis.
Other bodies are bigger, such as ABC and Yokomo... for 1/10 touring.
Joel
ohh i see now haha. thanks joel for the info, i might have to cop me one :P
anthony390 is offline   Reply With Quote
Old 07-02-2007, 04:51 AM   #1172
Phroz's Avatar
Hey guys a little while ago i wanted to make a drift shell with neons.. i could'nt find alot of info so i did some research and had a go. As a result of the interest from my local drift club i did a online tut. Sooooo here is the link if anyones interested (mine is the Blue Nissan 350z)
http://www.takeforum.com/rcdrifttoow...ttoowoomb#3020
Cheers,
P.
Phroz is offline   Reply With Quote
Old 07-02-2007, 06:25 PM   #1173
driftmeister's Avatar
Default norcal drifters
anybody from norcal here?
driftmeister is offline   Reply With Quote
Old 07-07-2007, 03:44 PM   #1174
Default 1:10 drift competition in vallejo
also r/c drift competition for all level(open) j-style
pm me for info
Old 07-07-2007, 06:26 PM   #1175
Trader Rating: 59 (100%+)
Big event in 2 weeks @ HPI's U.S. facility! (click image for more info)
TwinKays is offline   Reply With Quote
Old 07-08-2007, 06:44 PM   #1176
Serandin's Avatar
I just finished a new drift vid. Check it out: http://www.youtube.com/watch?v=CwhGLBvMsPI
Team CFX
M03, M04, TRF Evo IV Drifter, f201
Serandin is offline   Reply With Quote
Old 07-08-2007, 09:21 PM   #1177
RoOkie_Rx7DriFt's Avatar
Talking HmmMm
Cant wait ..my rx7 tt01-d is comming this week .. anybody here have people meet upz? down in daly city or san jose? ... want to meet with people that does drifting maybe can learn and practice sumtimes...
RoOkie_Rx7DriFt is offline   Reply With Quote
Old 07-09-2007, 01:11 AM   #1178
Suspended
403forbidden is offline   Reply With Quote
Old 07-09-2007, 01:20 AM   #1179
Dorigecko's Avatar
Send a message via MSN to Dorigecko
find more info on that MA60! that looks beef
Dorigecko is offline   Reply With Quote
Old 07-09-2007, 11:30 AM   #1180
Send a message via AIM to sloshedmr_bones Send a message via Yahoo to sloshedmr_bones
Well the rain finally slowed donw here and gave me some time to drive, drift and i was having problems with the temps getting really hot. I am running a Mamba max brushless 5700kv in my car with 87 or 88 spur with a 17t pinion. The spur is neon yellow if that helps and i know theres 2. Didn't get through a full pack before it got too hot. Any suggestions on gearing it. I have tried 18t pinion and thats didnt work the settings on my esc are stock settings. I just dont wanna keep buy pinions and find out its the wrong one. Some info would be great. I have read the gearing on castles website but thats is a guideline more than anything. HELP PLEASE!
sloshedmr_bones is offline   Reply With Quote
Old 07-10-2007, 03:33 PM   #1181
What ratio are you using though mate, and what chassis is it? Im currently running a 4600 with an 8.35 ratio and PE (similar to abs) tyres. Mine gets rather hawt aswell. But here are my suggestion.
Motor timing on low or lowest, gives you a bit more runtime aswell.
Try lowering your punch control aswell, this might help in the fight against heat.
Try a higher ratio gear combo. If you can go any higher that is.
I strongly recommend you invest in a fan for the motor, but also for the esc. it makes a hell of a difference temp wise
Drift Demon is offline   Reply With Quote
Old 07-11-2007, 12:28 PM   #1182
Default help on setting tt-01
hi, i'm a noob in rc cars..can i know wat is toe in toe out, and wat is the perpose??and does drift car need to toe in/out? i'm setting up my tt-01 with pvc pipe( white colour), but does not drift well, its takes a very very wide drift, like flying out. and must i change the shock (using nor tamiya)? i'm using sport turned motor with 19T gear is it ok? txs
liao79sg is offline   Reply With Quote
Old 07-12-2007, 11:05 PM   #1183
ok tried the car with the new gearing i am running now which is 88/16 *1.83 for a fd of 10.065 and all the esc settings lowered to the lowest and the esc , motor, and battery fried. The battery expanded, the motor just quit, and the esc wires melted. I dont know what else to do. I took the motor out before i did anything and the car rolled freely nothing was binding. Now what? I have tried everything anyone has thrown at me and nothing has worked yet. suggestions again. Thanx
Pinion is about all i can change. The spur i am limited to. comments, suggestions, anything
Old 07-13-2007, 08:26 AM   #1184
anthony390's Avatar
toe in is when the front of your wheels point toward the center. and toe out is just the opposite. in cases of grip, the purpose of having toe in is to have your car harder to turn in. and toe out will help your car turn in. so depending on your car's settings, it all depends on you and how you drive. try zeroing the car out and she how it feels first. then if you feel like you need to swing the car more try toe out and vise versa. i hope i did you some good
Old 07-13-2007, 12:24 PM   #1185
Serandin's Avatar
Ya an FD of 10 is pretty high. You should probably have it around the 7.0-8.5 region. Make sure you dispose of those batts properly, if they were expanding then they could leak. Also, what batts were you using? Your typical stick pack can't handle the loads a brushless setup will pull, the conectors tend to fail. Also stick packs can't be balanced and if one cell is significantly lower in charge than the others it will fry badly by over discharging when the pack still seems to have juice left in it. Don't run the car till it can't move anymore, stop when it starts to feel soft, and give plenty of cooling time between runs.
Team CFX
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 09:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 02:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 09:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 10:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
