Old 12-14-2006, 03:11 PM   #1006
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
i've got 26mm Rims. I've already looked and it wont be a direct fit, im going to have to sand some down of the rim.
vi3tishduy is offline   Reply With Quote
Old 12-14-2006, 07:06 PM   #1007
Dorigecko's Avatar
Send a message via MSN to Dorigecko
vi3tishduy, ross means 50mm and 52mm in diameter. The width is immaterial in essence, as you can cut it to whatever width you want.
You might find when it doesn't fit even with heat, you have to grind off the inner lip of the wheel to fit it on. I had to with my PSE rims. Its relatively easy, you can do it with a hand file if you can be bothered, but a bench grinder is good. Just don't think you can put regular tyres on after that, that's all.
If the ABS is too big, what some guys have done (didn't dave do it ross?) is tape around the wheel until it was a snug fit, then just push it on.
Dorigecko is offline   Reply With Quote
Old 12-14-2006, 10:00 PM   #1008
vi3tishduy's Avatar
the tire wont even fit in the abs pipe with out me trimmin the rims
Old 12-14-2006, 10:18 PM   #1009
Dorigecko's Avatar
then trim the rim.
simple.
who needs tyres? grip racing is for faggots.
Old 12-15-2006, 06:22 AM   #1010
vi3tishduy's Avatar
have you tried puttin em in the oven for like 10 secs?
Old 12-15-2006, 06:36 AM   #1011
Dorigecko's Avatar
thats another way that they do it, however boiling is much better, as it gets an all-round heat source, and not the addition of the hot pan melting the face of the tyre.
Old 12-20-2006, 03:57 AM   #1012
Built B16A's Avatar
Default question about front one way's..
so ive been reading up on this front one way diff.. and from what i get out of it is, on the throttle, your 100% on the drive shafts.. once you let off the gas, the fronts spin freely and wont accept braking power..
now.. this is quite expensive.. associated being top of the list.
with the physical construction of the one way diff.. isn't it all in the housing bearings?
i found AE part number 1731.. the 1 way bearings them self for 8 bucks.. wouldn't you think i could just stick those on my diff now? and basically have a front one way without all that fancy aluminum? the aluminum diff in the kit is still a functional ball type diff. no different than the one thats in my car now. right?
one way bearing.. #1731 $8
one way kit.. #1728 $61
Built B16A is offline   Reply With Quote
Old 12-20-2006, 04:46 AM   #1013
i cant stand drifting with a oneway once u get on the breacks and turn u spin u got nutral and turn u spin... i find the most effective bass is to ball diffs tighten the rear one and tighten the front just alil so it is stiff but still turnable.
Mr.Roboto is offline   Reply With Quote
Old 12-20-2006, 01:27 PM   #1014
Serandin's Avatar
Default I like oneways
I like one way diffs for racing and for drift.
As for converting a ball diff...
...I don't know how well this will work. A one way diff doesn't usually have balls in it (at least for the tamiya ones). The contruction is quite different from the standard ball diff, no grease, no balls, no thrust bearing, etc etc. But you could try it.
Team CFX
M03, M04, TRF Evo IV Drifter, f201
Serandin is offline   Reply With Quote
Old 12-20-2006, 07:39 PM   #1015
Built B16A's Avatar
the construction of the diff looks very similar.. i dont' know for sure, but it obviously has to fit in the same diff cover's..
anyways, i should of looked alittle harder.. but it seams the outdrive cups on both units are different sizes.
i figured i could use the same 1 way bearing on my stock setup, but they're different diameter outdrives.
oh well, i might be on the market for a front one way soon.
Old 12-21-2006, 02:33 AM   #1016
Dorigecko's Avatar
whatever the guy who said he spins all the time said, it doesn't apply to all cars.
if you start spinning out, give it some stick and you won't.
i've got both of my diffs locked. they're gear diffs, and i've just stuck some cotton fabric to lock em. best and easiest way to do it I say. no stuffing around with different greases or anything. just lock it and fuck it.
Old 12-23-2006, 12:49 AM   #1017
WheelNut's Avatar
Send a message via MSN to WheelNut
Does Tamiya still make the R32 body?
•Brad Comis
WheelNut is offline   Reply With Quote
Old 12-23-2006, 03:19 AM   #1018
vi3tishduy's Avatar
If you lock your diffs how do the cars go? do you just stuff cotton balls inside the outdrive box? also what do you guys think is best for drifting, shaft or belt? Im going to invest in a ta05 because my tc3 is falilng apart. I'm not willing to invest in it anymore sigh.. Its nicely hopped up but not worth it to keep it up with the parts. Ta05 here i come baby.
Old 12-23-2006, 03:07 PM   #1019
seth556's Avatar
Trader Rating: 37 (100%+)
Supposedly shaft drive is better but it makes a minimal difference. The TA-05 is an excellent drifter. I lock both of my diffs for a little bit more oversteer. I lock them with JB quick. But then when I convert it back for rubber tires the JB quick comes out somewhat easily.
seth556 is offline   Reply With Quote
Old 12-28-2006, 04:06 AM   #1020
Built B16A's Avatar
Originally Posted by vi3tishduy
If you lock your diffs how do the cars go? do you just stuff cotton balls inside the outdrive box? .
for my car.. a TC3.. we have ball style diff's.. so by removing the actuall ball's out of the diff, and tightening down the set screw.. the diff doens't have the chance to equal out, and offer better steering.
right now i have the fronts stock. and the rears tightened to the MAX on the balls.. its working out pretty well. i just want a front one way, so i can pull the e-brake and swoop a huge 180.. hehe
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 10:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 03:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 10:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 11:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 04:09 PM
SEO by vBSEO 3.5.0
