Old 11-22-2006, 08:24 PM   #961
AdrianM's Avatar
Originally Posted by Bunsincunsin
So they are basically an ABS tire.....That are $19.99 a pair?.....
No. They are a very hard molded rubber. More traction than plastic...less grip than soft rubber.
Adrian Martinez
Old 11-22-2006, 10:41 PM   #962
Originally Posted by samcook90
okay
ummm should i buy the trinity monster horsepower stock motor...too
what is that
thanks
Huh?
If you get the Associated TC4 rRTR here is what you will need:
Radio Batteries: (8) AA size
Battery: 6 cell w/standard connector (stick or side by side)
Charger: AC/DC timed or peak for 6-cell battery
Misc. Items: Building and track equipment
Bunsincunsin is offline   Reply With Quote
Old 11-23-2006, 12:14 PM   #963
Okay soo do most people perfer ummm actualy yokomo drift tires or a type of drift tire or doo the perfer pvc or abs which i have no clue what that is.
thanks sam
samcook90 is offline   Reply With Quote
Old 11-23-2006, 12:23 PM   #964
thanks sam
It's all preference.
A lot of people use ABS because it is way cheaper than buying a name brand tire. ABS is a type of pipe, used in plumbing. You can usually find it at any hardware store. If you get this you will want 2" diameter pipe.
Old 11-23-2006, 12:31 PM   #965
sooo its the same as pvc? umm what size wheels should i get 26mm? and if i goo with 26mm then should i get 26mm tires too or doo i need to get bigger? thanks
Old 11-23-2006, 12:37 PM   #966
kracka's Avatar
Trader Rating: 4 (83%+)
Originally Posted by DA_cookie_monst
Thought I would jump in with this thread.
Whats the drift tyre/plastic for using on Carpet chaps, as it is FAR to cold and damp for outdoors at the mo....
TB-02 drifter here
pvc are the best tires too drift on carpet trust me i do it all the time at our local track tried yokomo s ok but pv c is alot better
kracka is offline   Reply With Quote
Old 11-23-2006, 12:39 PM   #967
kracka's Avatar
abs pipe is heavyer than pvc and you can get pvc in black to look like a real tire
Old 11-23-2006, 06:26 PM   #968
soo pvc is easier to drift with?
Old 11-23-2006, 06:33 PM   #969
doo i need to put pvc on all for wheels right?
Old 11-23-2006, 07:12 PM   #970
A Ilievski's Avatar
Trader Rating: 39 (100%+)
yes on all 4 wheels,
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 11-23-2006, 10:38 PM   #971
ABS is similar to PVC, but ABS provides more grip then PVC when drifting on asphault.
Yes, you will need to use 26mm wheels and tires.
Old 11-24-2006, 09:08 AM   #972
okay soo i was looking around at getting one most likely over the internet... Is the TC4 RTR tthe same kit as the AE 1/10 RC10TC4?
thanks sam
Old 11-24-2006, 10:59 AM   #973
Yes.
Old 11-24-2006, 11:39 AM   #974
okay thanks a lot, soo lets get off the topic of me by theway thanks a lot for all the help... Ummm sooooooo wat doo people perfer too drift with on their wheels?
Old 11-24-2006, 12:04 PM   #975
As in tires?
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 10:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 03:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 10:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 11:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 04:09 PM
SEO by vBSEO 3.5.0
