Old 08-03-2006, 11:51 PM   #811
hi! newbie to the forum but ive been drifting for awhile with my "SUPER STOCK" TL01 (still even has plastic bushings and MSC!!!) ....
what kind of stuff do i fill the diff that doesnt cause permanent damage to the diffs? im now into drifting but sometimes i like to run my 01(not drift) (or maybe offroad).... and also, does locking really help cause ive been able to drift without locking the diffs. does the car respond better to throttle and steering if u lock the diff while going sideways?
Davel is offline   Reply With Quote
Old 08-04-2006, 12:39 PM   #812
ljohnson's Avatar
In my experience , the looser the diff the more the wheels grab for traction. In other words a loose (as opposed to tight, not slipping) diff regains traction easier. Since in drifting you don't want to regain traction and end your drift having the diffs tighter helps.
Completely locking either diff isn't needed, but a locked front can make steering and breaking feel more consistent.
ljohnson is offline   Reply With Quote
Old 08-04-2006, 01:04 PM   #813
ljohnson's Avatar
Just to be clear - this is on a TA04 on abs which has too much castor (6 degrees?), kick up, anti squat and roughly 40:60 front:rear weight distribution. The spool helps because it minimizes the steering inconsistency from the castor.
Old 08-05-2006, 07:16 PM   #814
scoobydo's Avatar
OK so my racing days with my Pro4 are over.
I want to try turning it into a drifter.
Anybody have a setup sheet for a Pro4 for Drifting?
I have a ton of parts for the car so I'm pretty sure I have everything I would ever need.
I just need to know what the norm is for drifting. (Spool, One way, Diffs, damper setup etc..)
Some info or a starting setup sheet would help.
I tried to search for "Pro 4 Setup" but got nothing.
Thanks.
scoobydo is offline   Reply With Quote
Old 08-05-2006, 07:29 PM   #815
anthony390's Avatar
Send a message via AIM to anthony390
Thanks.
someone on board this site with a name of angryasian should be able to answer this for you
he should just be lurking around here
anthony390 is offline   Reply With Quote
Old 08-05-2006, 07:35 PM   #816
anthony390's Avatar
may i say your not 100% true on that quote
you have to remember that we are just drifting with 1/10 scale cars on abs...the traction is already loose enough so not to worry about regaining full traction as long as you have the nessesary power and touqe... unless your talking about carpet that has some remains making it a bit grippy that is
and a looser differential just doesnt mean more traction but the power is just wasted on a wheel that is on the "less reseistant side" rather than a tighter diff that wont slip as much and the power would be used on tires slipping on the track...im not sure if that made sense but im sure youll understand it sooner or later
Old 08-06-2006, 07:12 AM   #817
MK_Arbiter's Avatar
Does anyone know the proper gearing for the TT-01 and TA-04? I tried out my new drift tires with my 04 on friday and it sounded like the stock gearing is too low.
MK_Arbiter is offline   Reply With Quote
Old 08-06-2006, 06:04 PM   #818
Aluma's Avatar
Hi y'all...got a quick question. Before that though, I've been drifting my TA04R for several weeks now. I have a Reedy19Turn motor geared at 128T/34T with a 6000lipo pack running ABS tires at 0deg camber all around.
Springs are tamiya yellow F/R and sways yellow F/R...stock shock positions. I can do some rather nice drifts at low speeds and hold the angles, do continous circles and what not. Problem I encounter is at high speed. I slowly build up to high speed and go full lock left with intent of getting the tail out with throttle but the car just keeps going straight even though the wheels are turned all the way...that is until it slows way down then it'll do it. So the question. How/what do I do to my suspension to get that tail out at high speeds so I can drift correctly? Is my gearing okay for the motor?
Aluma is offline   Reply With Quote
Old 08-06-2006, 07:21 PM   #819
Thought I might try to revive this thread and post my new body I did this weekend.
ev0l is offline   Reply With Quote
Old 08-06-2006, 08:06 PM   #820
anthony390's Avatar
looks good
just wondering if that would be the hpi silvia?
but might wanna try a different set of rms to set the taste of drifting
Old 08-07-2006, 02:16 AM   #821
ljohnson's Avatar
Yes, but neither of us is - we both sacrifice accuracy for brevity. If he'd wanted a long explanation he'd have read the whole thread and found the previous discussion. And you hadn't answered it yet..
Old 08-07-2006, 02:28 AM   #822
ljohnson's Avatar
You should have enough steering with that setup to break loose. I ran blue springs and no sway bar in the front, yellow springs and sway bar in the rear.
Try tapping the break as you turn. Throttle something like - on, break, full, control for drift. The timing of the steering and throttle changes will take some practice. Also, with that car, you may get more steering before full lock that at full lock.
Old 08-07-2006, 08:39 AM   #823
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
im back, i was grounded for a bit.
and PAZ that is crazy that oval racer, but what it really needs is that new mamba system, that would be awesome.
heck throw some rubber drift tires on it. that would be
it would be..
PAZ-TASTIC!!!
thats my new term for a over the top r/c car.
thedudeaturdoor is offline   Reply With Quote
Old 08-07-2006, 09:23 AM   #824
anthony390's Avatar
i wasnt trying to correct your answer, but your explaination
haha wlecome back thedudeaturdoor
Old 08-07-2006, 11:57 AM   #825
PaZ
PaZ's Avatar
haha i like i like, mamba system naaa im saving up for a novak 3.5R i need to make some new drift tyres before i go out i killed the yoko's oh thats another thing i managed to kill
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 09:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 02:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 09:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 10:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
