Old 07-25-2006, 01:19 AM   #781
MK_Arbiter's Avatar
How do you do a 360 like the one they did in the sg drifters second video?
MK_Arbiter is offline   Reply With Quote
Old 07-25-2006, 08:30 AM   #782
anthony390's Avatar
Send a message via AIM to anthony390
that is fairly simple, all u have to do ir turn right or left on ur choice and dont counter steer or let go of steering... say u turn left, continue to turn left and play with the throttle just a liitle bit and your car will soon do a 360 or more depending on how long you are going to hold the steering to the left
fairly simple just go out and try it for your self
anthony390 is offline   Reply With Quote
Old 07-25-2006, 09:56 AM   #783
Serandin's Avatar
Default One more thing
You generally need to do a hard counter steer towards the end to recover from the spin. It's all about throttle control.
Team CFX
M03, M04, TRF Evo IV Drifter, f201
Serandin is offline   Reply With Quote
Old 07-27-2006, 10:07 AM   #784
bikedoctor's Avatar
Great thread guys.....thank you.
I just got a TC4 RTR and would like to drift. As this thread reads I should go to Home Depot get some 2ft sections of ABS and put them on some rims.
How do I put the ABS on the rims? CA or Servo Tape??
I would love to know what you guys do to build up drift wheels. My rims are new and have all the ridges for rubber tires. I'm assuming I will have to dremel one side off. I would appreciate your knowledge.
Kevin
bikedoctor is offline   Reply With Quote
Old 07-27-2006, 11:23 AM   #785
Serandin's Avatar
Default Drift abs
It's pretty simple really, cut your abs to size then scuff up the inner lip a bit, scuff the outer lip on your rims, push the rims into the abs and add some ca. The scuffs will help the ca hold the abs on the rims, smooth plastic doesnt bond as well.
Oh, you should then sand down the edges of the abs as otherwise it will tend to bite into the road on cornering which will really screw with your drifts.
Team CFX
Old 07-27-2006, 01:18 PM   #786
MK_Arbiter's Avatar
How do you guys cut your abs? I'm using a hacksaw but i keep cutting the pieces of abs slightly diagonally.
Old 07-27-2006, 01:30 PM   #787
ljohnson's Avatar
I've been using a hacksaw and a miter box. A pipe cutting tool is better, getting a straight 90 degree cut. Clamping the pipe well and making sure it's laying flat with no unsupported length helps keep the cuts straight.
ljohnson is offline   Reply With Quote
Old 07-27-2006, 01:56 PM   #788
Serandin's Avatar
Default Pipe cutter
I bought myself a pipe cutter. It's supposed to cut pipe up to 2 1/8 in diameter. It turns out the ABS is just a tiny bit more than that. Damn. It was the biggest one home depot had too.
Back to using lewis's hack saw I guess.
Team CFX
Old 07-27-2006, 05:38 PM   #789
anthony390's Avatar
well i never bought a single drift tire...all i use and used or have has been my own abs tires...what i do simply is buy the regular abs piping for about 6 bucks for 12 ft i believe it was
i but the rim im going to use nest to the pipe so i can have an idea width i need to use.
after that i use any old hack saw and a plastic guide and cut it....i pre mount the tires but only to check if its good enough width for the wheel (the sides are still diangled)
after that i take out the rim and then mount the abs tire on to a lathe, i use the lathe to flatin out both sides so it matches the rim how i want it
once im done with the flated/even sides i can now work on rounding off the edges for more effecient drifts and better looking too
once all 4 tires are shaped,even, and rounded i simlpy mount on the tires with a super thin double back tape and i slide on the rim
wala im done!...well this is what i do and is, lets say 45 minutes for a good set of wheels
Old 07-27-2006, 07:35 PM   #790
bikedoctor's Avatar
Thanks guys. Of all the sites I've visited on rc drifting this is the one I like best.
Anthony........ is that the same double stick tape 3M makes for gift wrapping. I found some at Walmart and I think thats what your talking about.
I like the idea of using double stick tape. Seems it would be easier to mount new ABS on when time comes to replace.
Old 07-27-2006, 07:52 PM   #791
MK_Arbiter's Avatar
I taped the wheel and tire to a motor to round off the tire. I'm using CA glue cause the abs doesnt fit tightly on the wheel.
Old 07-27-2006, 10:33 PM   #792
supradude's Avatar
well guys i was reading some where that you could use electrical tape wrapped around your tires and so i tried it ....and come to find out it actually gripped better than some of my old rubber tamiya tires so im gonna have to try this abs stuff
supradude is offline   Reply With Quote
Old 07-28-2006, 12:54 PM   #793
anthony390's Avatar
im not sure if its the same but i know that my double sidded tape is just as thin as scotch tape...is yours also?
and supradude the electrical tape also works just as great for mounting the abs on
some people put a light narrow foam that has adhesive on underside to stick on the rim..and then cover it with a nice layer of electrical tape....electrical is soft and gets warm easily...so when yoru sliding the heat gets to the electrical tape making it almost glue"y" to the tire
Old 07-28-2006, 02:16 PM   #794
ljohnson's Avatar
Yeah, electrical tape is fairly grippy, it's not quite as sticky as sorex 40's at the temps I've run at. But it's not just stickiness that gets you traction with taped tires, the softness of the sidewall and insert will also buy some traction. This is why the yokomo treaded drift tires recommend using inserts for less grip - harder/stiffer tires grip less.
From what I've tried, from least to most grip: (?on guesses)
Abs
? pcv
?worn foam core abs
taped tires
hard race tires (40's etc) (depends on track temp)
HPI x patterns :P
good grip tires
There are some other changes besides grip - ie the sharpness of losing and regaining grip varies, mostly as an effect of stiffness.
ABS is the most fun because you don't need to go fast
The Yokomo tries looked the most like real car drifting
On asphalt tape was least consistent, followed by the 40's
On carpet rounded, fresh abs was best.
Old 07-28-2006, 02:23 PM   #795
supradude's Avatar
was it cause i was runnin a 19 t motor?.....should i try it again with my 14 t?
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 09:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 02:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 09:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 10:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
