Old 06-09-2006, 02:14 PM   #661
PaZ
PaZ's Avatar
sweet good luck man oops got the wrong sizes
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 06-09-2006, 07:11 PM   #662
anthony390's Avatar
Send a message via AIM to anthony390
i would go with the yokomo super drift radials if your on carpet
havent tried the tamiya drift tres but i think they would be quite promising
anthony390 is offline   Reply With Quote
Old 06-15-2006, 08:04 PM   #663
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
where is everyone?
thedudeaturdoor is offline   Reply With Quote
Old 06-15-2006, 08:06 PM   #664
mitchsterbrau's Avatar
Originally Posted by thedudeaturdoor
where is everyone?
ausdrift.net?
mitchsterbrau is offline   Reply With Quote
Old 06-15-2006, 08:53 PM   #665
anthony390's Avatar
well im still hwere but i dont really have anything to talk about
if someone needs anykind of help post it so we can keep this thing going
Old 06-16-2006, 08:16 AM   #666
Serandin's Avatar
Default Ok, here's something
Anyone have any setup tips for running ABS or yokomo's on carpet? On asphalt you're practically skating on ice, but ozite's got some serious grip. I'm thinking stiff with a fair bit of caster to try and keep the wheels flat. Don't want an edge catching the carpet.
Any thoughts?
Team CFX
M03, M04, TRF Evo IV Drifter, f201
Serandin is offline   Reply With Quote
Old 06-16-2006, 12:53 PM   #667
anthony390's Avatar
Any thoughts?
may i ask what car?
Old 06-16-2006, 02:22 PM   #668
PaZ
PaZ's Avatar
im still here just about we got kicked off our drift spot they said our radio gear was setting off there new tech alarm system......the fact its still going off when there is no one anywhere near the place might just prove its not us but they wont believe us oh and the fact that the esc caught fire doesnt really help
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 06-16-2006, 02:59 PM   #669
Serandin's Avatar
Default setup
Team CFX
Old 06-16-2006, 03:01 PM   #670
Serandin's Avatar
Default setup
Originally Posted by anthony390
may i ask what car?
A TA04 currently.
Team CFX
Old 06-16-2006, 09:56 PM   #671
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
OK, I got one. My daughter has this friend. And He wants to argue with her about witch cars real drifters use but My ? is,
Don't it hafta be a 4wd car to drift?
I cain't any 2wd car drifting as the non-drive whells/tires won't have any drive to cause them to break traction. Is it me or is I rite?
PlainOleDave is offline   Reply With Quote
Old 06-16-2006, 11:45 PM   #672
with real cars RWD is the best when it comes to drifting, I'm sure with RC 4WD is better due to the lack of true brakes. But I"m sure you can drift with either...you can can't effectivly drift with FWD.
Fast20v is offline   Reply With Quote
Old 06-17-2006, 08:26 AM   #673
anthony390's Avatar
ok well real cars (1:1 scale) have complety different wieght ratios also depending on the car layout, such as FR, 4wd, MR, RR, etc
so as you can see the real cars that are usually used for drifting is rear wheel drives, as to the weight ratios the common one is the engine being up front
when you said "non-drive whells/tires won't have any drive to cause them to break traction" it is complety impossible to keep traction, you have to remember that the wheels even without drive are always under stress due the the car's and driver's movements and actions, i can list some examples such as: Turning under high speed causing to understeer(not enough traction for turning) or even oversteer(your turning wheel have more grip) depending on the way your driving at that moment, braking and then turning while still braking and then to prolong to drift would either be powerover or just using the gas to keep off traction, which is mostly use to drift with, and another one is that the steering is not always parallel to the driveline in which your car is taking especially when your car is already in an angle
one kind of a drift line is usually taken by braking and turning almost at the same time to break traction causing you to be able to drift
and an example for a grip line is braking and then turning with a slight overlap of those actions so the car doesnt lose enough traction to slide
get it?...now for the 1:0 scale car is 4wd to drift with is becuase of the traction is pretty low and the complety small wheel base, the wieght ratio is also involved, as most of these cars are made 4wd and have the motor in the back with the battery along side
to sum it up 4wd and rear wheel drive can both drift but the easist to drift with is the FR layout...front wheel drive cars can also drift but its harder becuase of the extra using of the hand brake and the car is usually slower
well i hope i cleared it up and i hope the arguement doesnt get too rough
Old 06-17-2006, 09:26 PM   #674
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
Hey, here's a drift thread! I generally try to stick to the other forums, but this is the only place my post will fit.....
Anyway..........
Me and a buddy went to see the latest F&F movie yesterday (I promised not to make Ricer/Riceboy comments, even though I was tempted. ) and it got me thinking. We have this drift car in the lineup.... lets make a similar type of movie. No storyline, no dialouge, nothing fancy (Like those guys from Singapore) but a fun, fast paced movie about our drift car.
We're not big import fans, but we did like the moves we saw on the big screen while watching The Fast And The Furious: Tokyo Drift, so we tried our hand at some. The movie shows our results. Check it out by going to the address below...
www.TeamPlatinumRacing.com/Movies.html
Let us know how we can set the car up better, drive it better, make future movies better, or just lead better lives in general! Thanks in advance guys.
Platinum_Racing is offline   Reply With Quote
Old 06-18-2006, 12:39 PM   #675
PaZ
PaZ's Avatar
i love that video
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 09:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 02:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 09:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 10:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
