Old 05-10-2006, 12:26 PM   #556
Originally Posted by kidrobot
whats a good set for a ta-05???and how can you cover the belt with the spare lexan???
good set? set up? i would try stock at first and wear in the ABS "tires" then see how it is and tune from there. just remember that when you tune you have to wear the tires in again a little til they sit flat and then go from there.
looking at the pic on tamiyas site
http://tamiya.com/english/products/5...f430/index.htm
get the lexan excess from your car body bend it into a box and try to cover the center spur/pinion/center pulley. also cover the rear pully right before the shock tower and cut an opening just for the belt on the top. do the same for the front. we used to do this for our old yokomo yr4's. we also used to cut holes right under the pulleys where rocks would get lodged, BUT i would not do that until you are sure you will never enter a TCS race or anything like that where modded chassis' are not allowed.
b
bdrift is offline   Reply With Quote
Old 05-10-2006, 02:39 PM   #557
groovy.
does the graphite chassis upgrade help my drifting in any way?
andresmirt is offline   Reply With Quote
Old 05-10-2006, 02:53 PM   #558
Originally Posted by andresmirt
groovy.
not worth the money yet. my tl01 and tt01 are stock chassis and are fast. just remember what you are doing. you are driving on abs. the biggest difference you would see is when you wear in your tires halfway. then it will be good. find a friend with a lathe take the tire down to about 2 mm. it should be good from there.
if you got the itch to buy parts, maybe the one way(pulley or front), you already got oil shocks that are basic upgrades for the other kits, so no need there. bearings, you got. maybe a hard pinion that wont wear out like the aluminum ones. tamiya tuned spring set. oh yeah....BUY DOTS the colored ones that you can make a course out of. or use a garden hose and lay it out + tape it down.
b
Old 05-10-2006, 03:04 PM   #559
anthony390's Avatar
Send a message via AIM to anthony390
groovy.
depending on what you mean like molded graphite or woven graphite
it does do something but not really noticed while drifting
as both kinds of graphite make the car sometimes stiffer it asl makes it light
most people want to get their car stiff as possible, so they can perform longer drifts
but since your running on abs the traction is already low as heck
im kinda of the racer or drifter that always does something that a crwod doesnt
i like to make my chassis light but i dont want it to be stiff for drifting
as when the chassis is more flexible (torsonal flex) the grip is increased
thats what i like since im drifting
the choice is yours
anthony390 is offline   Reply With Quote
Old 05-10-2006, 06:43 PM   #560
Aries326's Avatar
Trader Rating: 19 (100%+)
There were probably land issues dating back to the original Hawaiians? We have those problems here in NY with the Indians making casinos and trying to not pay taxes. Anyway, back to drift...
Yeah, airborneranger probably wouldn't be able to hook you up with a Yokomo sponsorship since most of you guys run Tamiyas. Maybe you guys could do what Ben did, prepare a presentation and send it to Tamiya?
I've got a MR4TC Special and getting rocks in that thing was a PAIN. Belts were always getting chewed up and parts are hard to find for it. I've since retired the car and it just sits in a box in the basement. I never tried doing the lexan shield for it and I have heard of people drilling in holes on the bottom of the chassis where the diff case sits. How big of a hole were you guys drilling?
Originally Posted by bdrift
yeah, the real track closed because of land issues that were put off for as long as possible and of course your everyday corruptness of the people involved and lack of info on the state side.
i became a judge not just because of winning a lot of comps but mostly experience. plus it is good to have the same judge so people get consistent feedback and scoring. (assuming i know what i am looking for and judging on)
sponsorships would be nice. we have local shops giving us some stuff for the comps and streetcar showoff events.
andresmirt: ta05 sounds nice. just make sure you use your spare lexan pieces to shield your pulleys from rocks jamming them is they are not already protected. also, isn't projekt from FL?
b
Point1Drift
http://www.driftercentral.com
Aries326 is offline   Reply With Quote
Old 05-10-2006, 07:37 PM   #561
anthony390's Avatar
henry i think the hole under the chassis only needs to be about 2mm bigger then the hole it wouldve have been if u made it jst to clear the sight of the pully
i dnt know if you understood that but ill let the other guys clarify it for you
Old 05-10-2006, 08:11 PM   #562
Send a message via AIM to Projekt
hey im really havign second thoughts about getting that tc4. should i buy that or what would be a better car to gte to drift with?
Projekt is offline   Reply With Quote
Old 05-10-2006, 08:45 PM   #563
haha. no this is corruption from the 80's. nothing to do with hawaiians.
sheesh, if yokomo wanted to hook me up, i'll run all yokomo stuff i do have a drift spec that i am selling though. gonna try a SD just because it shouldn't feel as "sloppy" as my drift spec does. if they sponsor our meets and/or comps, we definitely would run a banner and stuff. most guys here run tamiyas because of the low entry cost. then they sometimes get more expensive kits. but the ones that started out with pro4's and stuff all got basic tamiyas as their backup and or main drift cars now.
b
Yeah, airborneranger probably wouldn't be able to hook you up with a Yokomo sponsorship since most of you guys run Tamiyas. Maybe you guys could do what Ben did, prepare a presentation and sent it to Tamiya?
I've got MR4TC Special and getting rocks in that thing was a PAIN. Belts were always getting chewed up and parts are hard to find for it. I've since retired the car and it just sits in a box in the basement. I never tried doing the lexan shield for it and I have heard of people drilling in holes on the bottom of the chassis where the diff case sits. How big of a hole were you guys drilling?
Old 05-10-2006, 08:49 PM   #564
anthony390's Avatar
y the 2nd thought?
if i had a chance to get a tc4 ill get it for sure
Old 05-10-2006, 09:27 PM   #565
Aries326's Avatar
Someone from GD said they don't get hooked up. I thought they did since they do so many shells. Maybe some of the guys get something. I know factory drivers usually get stuff at 50% off retail. Are they considered "factory drivers"?
Hell, I'll drift a DriftKing if they sponsored me. Hmmm, well, maybe not. lol...
You've been drifting alot and seem to have alot of experience with different chassis. What's your take on Yokomos being the best for drifting?
I sold an SSG Stage 3 Upgrade to a guy in South Africa (Odyssey) and he says that the drifts on the SSG are waaaay better and more predictable than the DP or even the TT-01. Alot of those guys in SA now want to switch over to the SSG.
But then there are those Yokomo haters that say TT-01s are all you really need. It might be all you really need, but are they that good once you get the right setup?
Drifting any of those high end chassis is pretty extreme. I've got an SSG myself but I bought it used and beat up. I can't get myself to beat up something as nice as a brand new Tamiya 414xx, SSG, BD, Pro4, etc...
b
Point1Drift
Old 05-10-2006, 09:37 PM   #566
SA22C'ya's Avatar
Send a message via AIM to SA22C'ya
SA22C'ya is offline   Reply With Quote
Old 05-11-2006, 05:15 AM   #567
Originally Posted by anthony390
y the 2nd thought?
Ordered one yesterday, it should be on the way, along with abc tires ...
I was ginna build project car with brushless setup, but don't know which system to get... but now I just need something to drift around the cudesac, and do not have too much time for the hobbies (car/airplane/heli). I decided to get the RTR, then upgrade later if needed.
Is the new Reedy 17T (they changed from 15T to 17T) comes with the new RTR enough for drifting?
CaptEvo is offline   Reply With Quote
Old 05-11-2006, 05:17 AM   #568
BTW, anybody drift in Atlanta, GA?
Old 05-11-2006, 06:28 AM   #569
anthony390's Avatar
Originally Posted by SA22C'ya
would you be the driver of that ae86 or your friend?
as for CaptEvo the 17t should be more than enough with abs tires
Old 05-11-2006, 10:26 AM   #570
does anyone know the difference in performance from the single ring yokomo drift tires to the double ring drift tires? are these tires any good to start off drifting? i like them...
i think i need a new shell for my car, i cant be drifting around in a Ferrari F430
Sg Official Drift Thread!!! AndrewJCH Singapore R/C Racers 188 08-05-2011 09:02 AM
Official Drift Thread Ginsu Electric On-Road 8 10-23-2007 02:36 AM
official drift thread streetracer745 Electric On-Road 3 10-24-2006 09:07 PM
The Official Drift Thread anthony390 Nitro On-Road 0 12-25-2005 10:46 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
